STL, STEP or IGES Interface in EMC
  • Dan Falck
  • Dan Falck's Avatar
  • Visitor
  • Visitor
28 Oct 2010 13:08 #4929 by Dan Falck
Replied by Dan Falck on topic Re:STL, STEP or IGES Interface in EMC
Yes, HeeksCAD should be able to deal with STL files for you too. I haven't played with STL to gcode generation in a while, but I think it's still working with HeeksCAD:
code.google.com/p/heekscad/
HeeksCNC is a plugin for HeeksCAD. Opencamlib is used for the solid model machining in HeeksCNC.
code.google.com/p/heekscnc/
code.google.com/p/opencamlib/
Dan
28 Oct 2010 13:50 #4930 by Midnightwolf
Replied by Midnightwolf on topic Re:STL, STEP or IGES Interface in EMC
Hi Mike,
I had a look into HeekCNC.
But I think it is a little bit strange to use. Normaly I'm using "CoCreate modeling". But I don't have an CAM converter in CoCreate. On the other hand I don't have any experience in GCODE writing. So I'm searching for a tool which will help to convert my drawings.
All of my drawings are finished in the used tool now, so it will be difficult to use a new tool. Also as I saw the CUT3D & PyCAM is working very well.
My opinion was to asking for an "filter interface" in EMC, like the "image-to-gcode". That will be a good solution for everybody as I think.
Thx
Benjamin
28 Oct 2010 13:56 #4932 by BigJohnT
Replied by BigJohnT on topic Re:STL, STEP or IGES Interface in EMC
A CAM program does much more than just filter a dxf file into g code. You need to select tools, feeds, speeds, coolant and other options as well as pick the geometry that you want to cut and what you want to with the cut like inside and outside and how deep and what DOC you want etc etc.
28 Oct 2010 14:00 #4933 by Midnightwolf
yes, I know... You are right!!
So the CUT3D Software will be a very good solution as I think. Because in that case you can configure all of that things.
28 Oct 2010 14:01 #4935 by Midnightwolf
it was just an idea to develop such an "filter" ... ;)
28 Oct 2010 14:04 #4936 by BigJohnT
Good idea! It would work for engraving as you follow the line and have a constant depth.
28 Oct 2010 14:15 #4937 by Midnightwolf
But isn't enough for my STL models....
Ok... I will take a licens for CUT3D in the next step. That will be the only way to translate my 3D models... :(
PyCAM is good for "easy" models... that will be fine for the first tests on my self made portal machine... ;)
28 Oct 2010 15:15 #4939 by andypugh
Replied by andypugh on topic Re:STL, STEP or IGES Interface in EMC
Have you looked at HeeksCAD? (I admit I haven't looked for some time)
29 Oct 2010 05:22 #4953 by Midnightwolf
Hi Andy,
yes I had a look into HeeksCAD. It's a little bit strange to use.... Also I had some trouble with the handling.
Regards
Benjamin
  • Der3er
  • Der3er's Avatar
  • Visitor
  • Visitor
02 Nov 2010 10:34 #5015 by Der3er
Replied by Der3er on topic Re:STL, STEP or IGES Interface in EMC
Well, a step or iges based cam module that would allow for even fairly basic toolpath strategies would certainly be GREAT! Obviously, it is not just an import filter but rather a complex affair as it should address at least some of the basic toolpath issues. And these are manifold. But still: It seems somewhat unreasonable to use either very expensive or very cheap software cam-packages that in their way will not fit the bill of most emc users. As of now I'm using cut3d and vcarve pro, they work well most of the time. BUT: the toolpath strategies are somewhat inferior -as one would expect, actually, at that price- and sadly it takes me more time to get the toolpaths done than designing my models in the first place.
A word of advice about cut3d: This is rather an ameteur-tool. It puts out toolpaths, yes. But do not expect something that will equal those from real world production packages. My 2 cts
Moderators: Dan Falck
Time to create page: 0.189 seconds
