- Thank you received: 21
Best cam software to use for plasma cutting
- tcbmetalworks
- Topic Author
2 years 1 week ago #313645
by tcbmetalworks
Best cam software to use for plasma cutting was created by tcbmetalworks
What's the best cam software to use for plasma cutting? I've tried fusion 360 and found it to unstable and not really geared towards plasma cutting. I like sheet cam I really do but I find it's missing some features. I don't know if it would be possible to easily add these features or if there's a open source option or a reasonably cheap cam program I can purchase (i cant spend 10 grand a year on a software). I would really like a program that supports. Auto nesting, skeleton cutting, tip up avoidance, wiggle or custom lead in would be sweet. Setting slats on the spoil board so you can see where your slats are positioned when nesting. A plate inventory system and cut time estimator / price calculator would be great but I can deal without it. Is there any options for a program like this or a program that is open source enough to modify your own scripts to add features like this? How is hypertherm pronest is it worth the money?
2 years 1 week ago #313654
Replied by tommylight on topic Best cam software to use for plasma cutting
It has none of what you asked, but it is very usable, Inkscape.
Open source, very easy to use, can do some nesting by using groups of ojects and layers, does leadin/leadout somehow, uses gcodetools extension included, so can be modified to your hearts content.
I just modified it to export the plasmac.cut.feed-rate, so i can use the material settings in PlasmaC.
- tcbmetalworks
- Topic Author
2 years 1 week ago #313675
by tcbmetalworks
Replied by tcbmetalworks on topic Best cam software to use for plasma cutting
I never really fully got the hang of inkscape. It sounds like it's the most open source but the least user friendly. I really want to try to build my table idiot proof so if I get lucky and it gets to the point I'm not doing all the work myself and I can easily have a newbie operator run the machine. I know linux cnc has plugins for plate centering is it possible to make this work with multiple work planes? So like if you load 5 sheets on the table can it centre all 5 or do I have to stop in between sheet.
- EW_CNC
- Thank you received: 24
2 years 6 days ago #313683
by EW_CNC
Replied by EW_CNC on topic Best cam software to use for plasma cutting
I'm using Hypertherm Pronest since 2017.
I do not have the full feature set subscription, which includes auto nest etc.
I find the manual nesting to be sufficiant and working good for my needs, I'm usually not nesting full sheets of steel.
It is not the cheapest software around, but I figure the yearly subscription maintainance fee is worth it if you do a fair amount of cutting.
2 years 6 days ago #313686
As for newbies, almost all machines i build are used by other people, sometimes people with absolutely no computer experience (yes i do bump into them occasionally), but it takes at most two days of 3-4 hours a day to learn to draw something or trace a path from a picture or image, edit it a bit, save it as gcode and use LinuxCNC to run that gcode. I am trying to say it is by far the easiest to use for plasma cutting.
Luckily, i do have a client that spent xxxx (nearly 2000$ i think, it was long ago) on every plasma CAM he could get, still uses Inkscape.
After all this i have a feeling you might take this the wrong way, as me pushing, well i am, so if you try other CAM's, please do report back how it goes, i would really appreciate it, a lot has changed by now in Plasma space.
What do you mean by "plate centering" ?
Inkscape is not a CAM software, it just has a CAM plugin that outputs gcode. It is a drawing/scetching/whatever it does software, so the CAM is just an add on made by a single user (probably with some help of others, but back then he was alone with about 500 people asking for help and features from him), but it does work magnificently for what it does.It sounds like it's the most open source but the least user friendly. I really want to try to build my table idiot proof so if I get lucky and it gets to the point I'm not doing all the work myself and I can easily have a newbie operator run the machine.
- tcbmetalworks
- Topic Author
2 years 6 days ago #313694
by tcbmetalworks
Plate centering so if a plate is set crooked on the table, you can define where it sits with 3 or 4 points. This avoids the chance that a plate is placed crooked operator error and it cuts off the side of the plate.
2 years 5 days ago #313750
Replied by rodw on topic Best cam software to use for plasma cutting
If you have F360, you just need sheetcam to build a good reliable system.
In F360, flatten your part (if sheetmetal) and then create a new sketch on that face.
Then you can right click this sketch on the left hand side and save as DXF.
Then open the DXF in Sheetcam and use the array function if you want to cut a few parts.
- CGT80
1 year 9 months ago #320276
by CGT80
Replied by CGT80 on topic Best cam software to use for plasma cutting
I use sheetcam and the addons for CandCNC electronics and software. Sheetcam does have a tab feature and could be used to keep parts from tipping up. You can set how many tabs and what size to use, so a single tab that is small might do the trick, but I have not used it for that purpose. You could make a dxf of your slat table and have that as a locked layer in sheetcam, then move your part where needed. My slats are 4 feet long and are set with a bow of 2 inches in the center so I don't worry too much about where they land. Ramp and wiggle lead ins are also an option, but I don't know if that is stock sheetcam or part of any addons from CandCNC. Sheetcam does calculate cut time with the simulation and it used to have a report feature that would tell you how many inches of cut, how many pierces it had, and the time to cut.
Inkscape certainly isn't cad or cam software and I only use it when I need to do graphics type work vs. geometric lines that are easier on cad. For cad, I use siemens solid edge community edition which is a free version. Businesses with the commercial version can not open the files from the free version, but it is fine to save as a dxf and import into sheetcam or fusion 360.
- blazini36
- Thank you received: 146
1 year 7 months ago - 1 year 7 months ago #325930
by blazini36
Replied by blazini36 on topic Best cam software to use for plasma cutting
Anyone just try using dxf2gcode?
I just got a little laser going and was a bit surprised there weren't more options. Nothing against paid software but it's alot easier to just try something out if it's open source.
I tried gcodetools for Inkscape, but I couldn't figure it out....probably just not patient enough. I went back and forth with dxf2gcode a couple of times and seems like I got it figured out. For some strange reason it doesn't have a plasma/laser configuration option, it's meant for mills I guess but I've never had the urge to use a DXF on my CNC mill so not sure it's really targeting the right group.
Anyway after some configuration that isn't quite obvious it seems I have it working pretty well. It does cutter comp but I don't bother since a diode laser kerf is pretty small.
Last edit: 1 year 7 months ago by blazini36.
- Hakan
- Thank you received: 405
1 year 7 months ago - 1 year 7 months ago #325949
by Hakan
Replied by Hakan on topic Best cam software to use for plasma cutting
I'm just using F360, I draw all my work in there, often using the sheet metal functions when the target is plasma cutting.
Flatten the part and insert some bend relief lines. Generate G-code.
The "new" F360 post processor works great. Spotting, small holes, cutting with and without lead ins/outs.
QtPlasmaC can do many things on its own.
Cutting using an rotated coordinate system no problem with a laser marker.
It can't do nesting but it can make multiple parts in one or two dimensional arrays.
Load the G-code and use the block feature in the conversational section.
QtPlasmaC can also do wiggle piercing or ramp piercing, just that this needs to go
into the post processor and there it isn't. So hand editing.
I was set on using Sheetcam again after I rebuilt the plasma table, which took long enough time that I forgot how to work with Sheetcam.
The "new" F360 post processor made wonders, that problem with "arc ends differ" was a real annoyance but is completely gone.
A drawback is the kerf width which is hard-coded in the G-code file. If I change my mind at the plasma cutter I must regenerate G-code for the new kerf width.
Regarding nesting, check out www.deepnest.net/en/ that does nesting of svg and dxf 2d parts.
A browser version of an early version to quickly try is here svgnest.com/ (skip deepnest.io)
Last edit: 1 year 7 months ago by Hakan.
Time to create page: 0.065 seconds
