Spanish translation, again
6 years 3 months ago #176699 by abu
Replied by abu on topic Spanish translation, again
Of course Andy.
tweaking-steppers.txt is not orphaned. It is a bad expression. When I say "semi-orphan file" I mean other forgotten details.
For example, in lines 30 and 42 the expression 'ovl max' appears. I can figure a newbie spending a lot of time finding out what 'ovl max' is since nothing appears in the latency window. In addition, the numbers do not match the figure in the latency test chapter.
I refer to these details.
6 years 3 months ago #176703 by andypugh
Replied by andypugh on topic Spanish translation, again
abu wrote: I mean other forgotten details.
You are probably the only person to read through the entirety of the docs in sequence for some years. This puts you in a unique position to spot this sort of thing.
So, I do think that the thing to do is to raise a bunch of issues on the issue tracker, and we can sort them out.
6 years 2 months ago #177497 by abu
Okay. A short break and a yoga session.
When I go further and further in the translation (the language does not matter) I realize the existing gaps.
One of the main "problems", I think, is that the developers have never been aware of the need for correct translations.
The question is, do you really need translations?
Well. This is a "metaphysical" question.
There is an unquestionable fact: more translations, more users. Operating systems are a clear example. Microsoft (or Linux, or Apple ... etc) would have a lower market share without translations.
I am not saying that LinuxCNC's goal is "market share." I say that many potential users run away (or have been eject) from LinuxCNC because they simply do not understand English. I say this from my own experience.
Internationalization / localization / translation is not a trivial process. There are a lot of people involved: developers, maintainers, translators, and even users. All this needs an exact, coordinated and seamless plan. Right now, that doesn't exist, I think.
I am carefully reading the GNU Translation Project and the gettext documentation. At the moment, any resemblance to the reality of LinuxCNC is pure coincidence.
I am considering proposing a general guide for translations based on the GNU philosophy. Perhaps that text could be part of the Developers Information chapter?. I don't know..
To be continue .......
6 years 2 months ago #179093 by MaHa
Replied by MaHa on topic Spanish translation, again
I did some research for a future project, i recognized some english html 2.8/2.9 docs, section 'Commands and userspace components' are in spanish now.
In 'Realtime components and kernel modules', the links are twice, and some of the info is in spanish also
6 years 2 months ago #179094 by andypugh
MaHa wrote: In 'Realtime components and kernel modules', the links are twice, and some of the info is in spanish also
What do you mean by "the links are twice"?
6 years 2 months ago #179095 by MaHa
it goes from abs to xor2 and following is in spanish:
at_pid
classicladder
counter
debounce
encoder
encoder_ratio
gantrykins
gentrivkins
gladevcp
hal_bb_gpio
hm2_7i43
hm2_7i90
hm2_eth
hm2_pci
hm2_rpspi
hm2_spi
hostmot2
kins
lcd
lineardeltakins
motion
mux_generic
opto_ac5
pid
pwmgen
rosekins
sampler
setsserial
siggen
sim_encoder
stepgen
threads
watchdog
weighted_sum
And then, the same again from abs to xor2.
randomly checking, in this section was all in english
Moderators: HansU
Time to create page: 0.059 seconds
