I can no longer access a Linuxcnc page
- Thayloreing
- Thank you received: 3
20 May 2024 11:00 #300995
by Thayloreing
I can no longer access a Linuxcnc page was created by Thayloreing
Good morning, I used this linuxcnc page to see the specifications of the linuxcnc components, but now I can even access the page, but when I click on a component to see the explanation, it gives an error saying that that page no longer exists, this Is it an error or has the page been discontinued? Follow the link at the bottom of the page, to test try pressing on a component it takes you to a page saying that there is no more information
linuxcnc.org/docs/devel/html/fr/hal/components.html
- Thank you received: 4151
20 May 2024 13:21 #301004
Replied by rodw on topic I can no longer access a Linuxcnc page
Your link works for me. Maybe there was a transient fault.
- strahlensauger
- Thank you received: 66
20 May 2024 13:44 #301006
by strahlensauger
Replied by strahlensauger on topic I can no longer access a Linuxcnc page
Yes, but if you click e. g. other components and then comp
you geht a 404 error..
- Thank you received: 2176
20 May 2024 17:34 #301018
Replied by Aciera on topic I can no longer access a Linuxcnc page
Seems the man pages are only accessible from the standard (english) page:
- Thayloreing
21 May 2024 01:30 #301046
by Thayloreing
Replied by Thayloreing on topic I can no longer access a Linuxcnc page
Is this problem an error or has the page been discontinued? Until last week I was using it, for me this page was very useful because I saw how to implement each component
21 May 2024 20:08 #301117
The links work in 2.9 docs so use that.
The list is very old and now very incomplete. (And probably unnecessary)
If you go to the main page, click expand man pages and all of the documents for every component are available. This is what your page is linking to anyway.
- HansU
21 May 2024 20:27 #301120
by HansU
Replied by HansU on topic I can no longer access a Linuxcnc page
Unfortunately not. It seems to work only for the non-translated docs.The links work in 2.9 docs so use that.
Not very old, but unfortunately not complete for the translated docs. For the English docs it is generated and all not assigned to a category are listed at the end. I think this gives a nice overview and is not unnecessary.The list is very old and now very incomplete. (And probably unnecessary)
- rdtsc
- Thank you received: 14
28 Jul 2024 17:06 #306247
by rdtsc
Replied by rdtsc on topic I can no longer access a Linuxcnc page
Wasn't there some recent issue with the docs build system and the French language specifically? Perhaps the two issues are related.
Moderators: HansU
Time to create page: 3.788 seconds
