User removed?
- Alarris
27 Dec 2024 11:47 #317489
by Alarris
User removed? was created by Alarris
Hello! I just re-signed up with the same email address and user name as previously. I was just wondering if users are removed periodically (I hadn't logged in for quite some time) or if there was some other reason my user was removed?
I just want to make sure I avoid whatever I did to make it happen so it doesn't happen again!
Thank you!
Evan
Thank you!
Evan
- Thank you received: 2177
27 Dec 2024 12:02 - 27 Dec 2024 12:10 #317491
Replied by Aciera on topic User removed?
Yes, we have started to periodically remove dormant users. In most cases this is in no way a 'punitive' measure but became necessary because our database had grown to almost 25'000 users with more than half of them dormant or simply spam accounts.
Thank you.
Thank you.
Last edit: 27 Dec 2024 12:10 by Aciera.
- Alarris
27 Dec 2024 12:13 #317494
by Alarris
Replied by Alarris on topic User removed?
No problem at all! Just wanted to make sure. Thank you!
The following user(s) said Thank You: tommylight, JT
Time to create page: 0.281 seconds
