Proposal to improve forum stability and structure
  • Muecke
  • Muecke's Avatar Topic Author
  • Platinum Member
  • Platinum Member
28 Feb 2026 17:15 - 28 Feb 2026 17:16 #343658 by Muecke
Hello JT,
It's a real shame that you don't have access everywhere.
Installing a Joomla + forum is not difficult in principle – the real challenge usually lies in maintenance and upkeep.
From what I've read so far, there are a few problems with the forum. Some functions do not work correctly or have been deactivated due to errors. In addition, the forum is often unavailable, which I find very unfortunate, as the community suffers as a result.
It may be possible to create a new folder under root and create a new database (the database software is already available). In this new environment, you could reinstall everything and set it up cleanly on a trial basis.
The new folder could be assigned a subdomain (e.g., forum-test.xyz.org). Everything could be installed and configured there at your leisure. Once everything is running smoothly and error-free, the subdomain could be adjusted accordingly and the old forum could be left as an archive – for reference and review.
I completely understand that your time is limited—we all feel the same way. Nevertheless, I would be delighted if we could find a solution together. This would certainly be very valuable for the community.
I would also set up a Joomla + forum myself, but I only have 5 GB of web storage—unfortunately, that's not enough. Therefore, it would make sense to implement it on your server.
Best regards
Mücke
Translated with DeepL.com (free version)
Last edit: 28 Feb 2026 17:16 by Muecke.
28 Feb 2026 17:29 #343660 by JT
We are actually working on updating all the software now.
The downtime of the forum is due to DDOS attacks.
We actually have more control than I thought.
JT
The following user(s) said Thank You: pommen, rodw, Hakan, Muecke, NWE
  • Muecke
  • Platinum Member
  • Platinum Member
02 Mar 2026 05:57 #343710 by Muecke
I'm glad to hear that you're in control and can update the system. That's good news. :-)
My thoughts are with you.
Mücke
The following user(s) said Thank You: tommylight, JT
Time to create page: 0.111 seconds
