Update your machine to use LinuxCNC and we might be able to help.i am controlling drive by using modbus 485, my controller is teensy 4.1 with wavetec RS485 module between drive and controller. the drive is being controlled in PR/velocity mode.. the PR mode is being used for homing and velocity for normal 360 degree rotations. i am facing issue in the end when the arm reaches to zero/home position.
