I think the forum needs some TLC
09 Oct 2026 15:30 #350172 by Unlogic
I think the forum needs some TLC was created by Unlogic
This forum has been more flaky than usual lately almost to the point of being unusable.
Is this something we in the community do anything about?
The forum is pretty much the heart of the community and it's noticeable less activity here when it takes minutes to load a page.
09 Oct 2026 17:49 - 09 Oct 2026 17:53 #350174 by sgd
Replied by sgd on topic I think the forum needs some TLC
The forum has been under a sustained attack for a bit over a day (not "more than a week", as the post above indicates). We're doing what we can to mitigate the attack. Please try to be patient as we work to keep the forum available. We're not going to disclose the nature of the attack nor the mitigation measures we're taking, so please don't ask about that.
Thanks.
Last edit: 09 Oct 2026 17:53 by sgd. Reason: typo
The following user(s) said Thank You: PCW, Muzzer, pommen, besriworld, JohnnyCNC, anfänger, JT, DSS, FabLabRacing, Unlogic
  • FabLabRacing
  • Junior Member
  • Junior Member
09 Oct 2026 23:15 #350178 by FabLabRacing
Replied by FabLabRacing on topic I think the forum needs some TLC
It is WAY better now, than it was this morning!!! A big thanks to all that worked on it!
The following user(s) said Thank You: Muzzer
10 Oct 2026 01:05 #350181 by snowgoer540
Replied by snowgoer540 on topic I think the forum needs some TLC
For what it's worth, I've been trying to get a forum page to load from Wednesday morning until this evening.
The following user(s) said Thank You: tommylight, Muzzer, NWE
10 Oct 2026 01:49 #350182 by sgd
I don't mean to downplay your experience - I believe you. The forum has been slow for quite a while, but usually works eventually, It got a lot worse yesterday morning when the current attack began in earnest.
Things seem to be better now, but are not optimal or even acceptable.
We'll continue to work on keeping the forum running reliably.
Thanks!
The following user(s) said Thank You: tommylight, Clive S, Muzzer, snowgoer540, spumco, DSS, NWE
15 Oct 2026 04:52 #350270 by tommylight
Replied by tommylight on topic I think the forum needs some TLC
Last two days it's been much better, thank you SGD.
Time to create page: 1.597 seconds
