Raspberry Pi GPIO Conversion CNC Software
2 years 11 months ago - 1 year 7 months ago #286004 by diy
我是一个CNC爱好者,创建了一个树莓派接口板,并编写了一个树莓派GPIO转换linuxCNC程序。欢迎使用。使用起来非常简单。您为 Raspberry Pi 定义的 GPIO 引脚输出 1,所有使用的引脚均为 0,将自动计算。我已经安装了 2.91 版本并编辑了 HAL 和 ini 配置文件,它们功能齐全,可以返回原点,可以连接手轮,并且可以用于 PWM 主轴。(英语不好,翻译)
软件下载
Last edit: 1 year 7 months ago by diy.
The following user(s) said Thank You: cakeslob
2 years 5 months ago #301722 by Cant do this anymore bye all
hmm the attached zip file contains an exe file.
2 years 4 months ago #302197 by cakeslob
hmm, i havent actually tried it out because I dont use rpi gpio so much right now. but it looked neat
2 years 4 months ago #302236 by tommylight
2 years 4 months ago #302241 by COFHAL
I think it is to calculate the GPIO values ​​of the RPi, like the image in the first post.
2 years 4 months ago #302242 by Cant do this anymore bye all
The utility may have been written in C# and may be executable with mono, but if you don’t have it installed it’s slot of packages just to run an executable.
But I just get a bit weirded out if no source and build instructions are there. Or it’s not a package from a known source. Switching from Slackware to Debian\Ubuntu based distros has made me a bit lazy.
Anyways didn’t JT write something similar in python ?
Time to create page: 0.075 seconds
