- Thank you received: 5334
CHARGE PUMP: The G540 is equipped with a charge pump (watchdog timer) that disables the drive without a 10 kHz signal on pin 16 of the DB25 port. You can enable this by reversing what was done in
STEP 3 and making sure that your parallel port is set to EPP mode. To do this, go into BIOS and set your parallel port to either “EPP” or “Send/Receive”; most parallel cards are set to ECP or “Send Only” by default.
