Then you need to make the encoder scale negative. Or possibly swap the encoder A and B phases.mariusl wrote: Servo system Andy.
mariusl wrote: Andy,
I made the encoder scale negative and the output_scale negative and got a huge runaway on that axis. I did not swap the A and B signal yet.
So I will have to keep the ENCODER_SCALE as is and make the OUTPUT_SCALE negative and swap A and B signals on the hardware connection.
PCW wrote: what final parameter does OUTPUT_SCALE actually change in your system?
Sounds like it did nothing (so you ended up with positive feedback=runaway)
