- Thank you received: 240
P.S. Is there a command I can have running in a terminal session that logs the status of the usb devices. I would like to see if all usb communication is lost and only some devices reconnect or if it is just isolated to certain devices.
If you want a live-updating terminal window with kernel messages in, then this works better:ArcEye wrote: Running dmesg | tail in a terminal will show when USB devices are mounted and unmount
It is a very old PC, and seems to suport USB only reluctantly anyway. (USB drives don't work)
