Help understanding what I might be doing wrong.
- cdslaughter
02 Jul 2013 03:24 #36212
by cdslaughter
Help understanding what I might be doing wrong. was created by cdslaughter
Let me explain. . .
I have built my gantry style CNC and am using a gecko 540 driver with 3 nema 23 motors. I have tried configuring the 6 switched (at the max and min of each axis) as all limit switches and with 3 as home and 3 as limit)
During this project, I have been taking it 1 step at a time, making sure that I have the correct understanding of how each component should work and that is does so before I move forward. This is where I would like a little guidance as I am not sure I have things correct. I have been trying to run the test patterns that come with LinuxCNC to make sure my Z, Y, and Z axes operate correctly. (Note that I have not yet installed the router on the Z axis. It is currently just an empty sled.) However I am having difficulties getting them to run correctly. I either have an Z, Y, or Z axes that has the incorrect + or - ranges, or while running, they slam into one of the limits unexpectedly.
Could anyone give me any advice on where to start? I am not sure I am even in the correct location to be asking these questions. As an example, on the Z axis, I have made the assumption that when it is at it's top most limit, that it would be considered "Homed" and that as it is lowered, that it's position would be a negative value, but that does not seem to be the correct assumption.
So if anyone would be so kind as to give me some ideas, I would greatly appreciate it.
Carl
Carl
- BigJohnT
- Thank you received: 1176
02 Jul 2013 03:54 - 02 Jul 2013 03:54 #36213
by BigJohnT
Replied by BigJohnT on topic Help understanding what I might be doing wrong.
It is perfectly normal to share the home and limit switches on each axis.
Z home is usually up and yes moving down is a minus move.
Have you set the scale for each axis and verified that the commanded move is the same as the actual move?
Have you seen my tutorials ?
JT
JT
Last edit: 02 Jul 2013 03:54 by BigJohnT.
- cdslaughter
02 Jul 2013 04:14 - 02 Jul 2013 04:16 #36215
by cdslaughter
Probably haven't set the scale. I did the stepper wizard, but ran into a micro stepping configuration issue with the gecko driver. In the end I had to set each axis's micro step to 5 (was supposed to be either 10 or 20) . But truthfully, I did not see any scale options. and for commanded movement, the physical machine moves up down, in out, left right the same as the digital one on screen.
No I haven't, are they on you tube? I looked at your profile and did not see any links
Replied by cdslaughter on topic Help understanding what I might be doing wrong.
JT
JT
Last edit: 02 Jul 2013 04:16 by cdslaughter. Reason: Clarification
- BigJohnT
02 Jul 2013 04:34 #36217
by BigJohnT
The link is kinda light blue and a bit hard to see but click on tutorials.
There is a scale number at the bottom and it is simply the sum of microstepping and gearing. The Gecko is 10 microsteps. You stepper should be 200 steps/rev and what ever gearing you have to move one user unit will be the scale. In the end the only number that matters is the scale number which has to match how many steps it takes to move one user unit (inch or mm).
JT
JT
The following user(s) said Thank You: cdslaughter
- cdslaughter
02 Jul 2013 04:52 #36220
by cdslaughter
Cool, thank you. I will take a look at it tonight when i get home.
I will take a look at your tutorials and go from there.
- cdslaughter
03 Jul 2013 05:08 #36255
by cdslaughter
Ok I did some reading and learned a few things. I took this knowledge home and put it to use. Now I am even more confused. So maybe you can help me figure out where I am going wrong.
There are two issues.
1) Setting up the 6 switches I have at the limit of each axis is proving a challenge. I have each of the axis’s minimum limit switch going to an input ( X to 1, Y to 2, and Z to 3). Those 3 switches are wired for normally closed. The 3 maximum switches are wired in parallel for normally open and connected to input 4. This was originally wired this way so that the 3 minimum limit switches could also function as the home switches. Unfortunately I have discovered that this is an unsupported configuration. So I have just set the 3 min limit switches as the home switch and not defined any limit switches until I get another parallel card for more inputs.
Is this a problem? I tried setting the minimum limit switches to act as home and min limit, but every time I homed an axis, it failed and reported a “Joint” error.
2) I have tried configuring my Z axis and am having all kinds of issues. The only difference between its configuration and the X ,Y axis config, is that is uses negative values instead of positive in the home location and table travel fields. If I set the values to a positive value, it will home correctly. However when I run the test gcode, it crashes in to the upper (top) limit (home) switch every time. When I reset it to have a table travel of 0.0 to -4.25 and a home location of -2.0 (home switch location is still 0.0) it fails to home and reports the following error.
“End of move in home state 7”
Any thoughts? Am I missing the obvious?
Any help would be appreciated.
I can post photos of the machine if needed.
Carl
Carl
- BigJohnT
03 Jul 2013 05:45 #36256
by BigJohnT
Wire each pair of switches for each axis N/C and hook to one input for each Axis. If your using the stepconf wizard select both limit and home for each axis.
What test code? If you mean the ill guided splash screen you have to read the hints in the first few lines of the file.
JT
JT
- cdslaughter
03 Jul 2013 09:00 #36259
by cdslaughter
Ok, so I have changed the limit switch wiring, but now my X and Y axis are trying to home by going the wrong direction. When it starts it's homing run, it moves toward the max limit switch and not the minimum limit switch. I went into the config wizard and reversed the X and Y inputs, but then I get a "Joint on limit switch" error. am I missing something obvious?
carl
carl
- cdslaughter
03 Jul 2013 09:22 #36260
by cdslaughter
and just in case I goofed up the config, I manually verified that the axis move in the commanded direction.
All kinds of lost now..
- cncbasher
- Thank you received: 288
03 Jul 2013 14:22 #36262
by cncbasher
Replied by cncbasher on topic Help understanding what I might be doing wrong.
it's usual to home to max z etc , as this would then home away from anything that was previously mounted
useful in lets say a mill or lathe , but in the case of a router then x and y can be set at minimum and your z set to home to max
then you would use the touch off in axis to then set your working point zero , which is totaly seperate from the home points
think of home as being the machine starting point and the touch off as being the work machining zero for use with gcode etc
the docs have some explanations of this ..
if you need home at a minimum point this can be done by changing the net of the limit switches to both-min rather than both-max
Time to create page: 0.078 seconds
