Parallel Port Does Not Work in Input Mode
30 Aug 2013 23:39 #38256 by fbx109
Hello all,
I am using LinuxCNC to make a 3 axis mill. I wanted to add some physical buttons to the machine and have them be read through the parallel port. I have 5 buttons and 3 limit switches so I needed to use the parallel port in input mode. I set that in the hal file as below:
# load parallel port
loadrt probe_parport
loadrt hal_parport cfg="0x378 in"
The pins that are always inputs 10,11,12,13,15 work as expected but pins 2-9 do not work at all. I tried all the buttons and limit switchs on the 10-13,15 pins and they all work, but no buttons or limit switches work on pins 2-9. I am using the Show Hal Configuration option in the GUI to see the pins change state. The hal configuration shows that the pins 2-9 are inputs. I tried setting the parallel port mode in the bios to output only, bi-directional, ECP and EPP, but all of the modes gave the same result. I am using Ubuntu 10.02.
Regards
31 Aug 2013 00:21 - 31 Aug 2013 00:24 #38258 by PCW
What motherboard and BIOS?
(I ask this because some Intel motherboard BIOs's are broken and
dont actually allow setup of the parallel port modes even though the BIOS
setup makes it look like you can )
Last edit: 31 Aug 2013 00:24 by PCW.
The following user(s) said Thank You: fbx109
31 Aug 2013 00:44 #38260 by fbx109
Replied by fbx109 on topic Parallel Port Does Not Work in Input Mode
I do have an Intel board, it is a D525MW. The bios string is mwpnt10n.86a.0083.2011.0524.1600. I am going to try to boot from a live CD to make sure I did not mess up any configurations. I will also try to find another computer with a parallel port.
31 Aug 2013 01:24 #38264 by PCW
The D525 is one of the Intel MBs that has BIOS bugs
that cause the BIOS parallel port setup to not work, but
linuxcnc _should_ be able to set the port modes.
Maybe someone else with a D525 can offer some guidance
A possible last ditch workaround is to install a PCI parallel port for more I/O
31 Aug 2013 10:04 #38279 by andypugh
Replied by andypugh on topic Parallel Port Does Not Work in Input Mode
On any recent version of LinuxCNC (2.5.x ) the p-port driver will just ignore the BIOS when it says it can't do EPP.
I am not sure that this is the same problem as reported here.
It may be worth noting that a simple switch on a parallel-port input needs to be wired to GND as the pins have pull-ups so sit at 5V.
31 Aug 2013 10:13 #38281 by fbx109
I ran the live cd with Ubuntu 10.04 and LinuxCNC 2.5. I had the same problem where only the default input pin work. I have the buttons wired to pins 6-9 and to ground pins 24 and 25. At this point I am stumped and will probably get a Mesa card that has I/O. I would get another computer, but this is the one I was given to work with. If anyone else has any other ideas, let me know.
31 Aug 2013 10:18 #38284 by fbx109
I just looked on Intel's website and there about 19 bios updates for the motherboard. I do not think the bios has ever been updated for the computer I am using, I will try updating next week to see if that fixes the problem. Thank you for all the help today :) I will update this thread with my findings next week.
26 Dec 2016 18:35 #84708 by kagouraki
Replied by kagouraki on topic Parallel Port Does Not Work in Input Mode
This must have been a looooong week....
I have the same problem. is there a possibility that there could be different cable types? the problem is that i have tried the onboard parallel too and it is the same thing. I have the one onboard out and two others as in. the in card behave as the other guy mentioned. from where i bought the cards he said they are Moschip MCS9901 but in lspci -vv says :
MosChip Semiconductor Technology Ltd. PCIe 9912 Multi-I/O Controller (prog-if 03 [IEEE1284]).
i am running linuxcnc 2.7.8.
any help appreciated
  • Moderator
  • Moderator
26 Dec 2016 19:58 #84709 by tommylight
Replied by tommylight on topic Parallel Port Does Not Work in Input Mode
I use a lot of NetMos pci cards and they do work properly as out in or X mode. Also the built in ones i use do work properly.
I wonder, did yout add the paraport read and write instances in hal for the other ( pci cards ) ports ? Without tehm it will not work.
To test inputs on a parallel port just short them to the ground.
When i get home i will attach a config i use for servo PWM drives with encoders directly connected to paraport and i have a VCP panel with all inputs and outputs added so you can see if they are working. It is set for X mode so 8 outputs and 9 inputs.
26 Dec 2016 20:03 #84710 by kagouraki
Found the problem... i have this chinese break out board with the 17 optocouplers(one on each pin). They are onedirectional... so... 60 euros wasted... Another question. Does anyone know what is the logic level of the parallel port and how safe is to connect direct all my input to the parallel port without breakout board?
i have only switches and one encoder. no motors relays etc. Thank you..
Time to create page: 0.386 seconds
