Time to jump in the water.....
- willysnowman
06 Nov 2013 14:51 #40576
by willysnowman
Time to jump in the water..... was created by willysnowman
Greetings,
I chatted with a few people over at the practicalmachinist site awhile back. I know Big John was one of them. They steered me in the direction of LinuxCNC. It is time to actually start using it.
I have a lot of experience building the mechanics of various control systems. I have never done the actual controls. I now have three projects I want to CNC. I am looking for advice on my which should be my first project.
One is a manual Birmingham 12X36 Lathe. I don't expect this to be a volume production machine. I just want something better suited for my prototypes. I tell it where 0,0 is, take off this much, this far, and this fast, and it does it. Threading and tapers would also be very nice. Just having a DRO would be nice. A gang setup may work, but I would probably get a better lathe. I am thinking I can do this for $1500 with VFD.
One is retrofit of a 2-Axis Bridgeport Eztrak. This would involve changing out the controls and adding a Z-axis. I believe I can sell most of the old working components, but maybe not.
On both the above, I would like to keep the manual handles but this may not be needed with the right control software. Eztrak is not the right software.
The last one is 3-axis CNC engraver. I do not have a huge need for this as I use the mill, but I thought it may be a good first project. The idea would be to use a high speed spindle from ebay and Nema23 motors to move it around. This would be used for general part marking. I think I could do the electronics on this for $500, but it may be less than robust components.
I do not want to start on the mill as the first project. I just cannot afford to have it down that long if there are mistakes. The lathe is a little more forgiving since there are two axis. I figure I can work out the controls off the lathe and install when I am comfortable. The lathe would give me the most payback. The CNC engraver is a nice to have. I see it as a minor challenge mechanically. It would allow me to get my feet wet slowly. Personally, I don't mind jumping in. Drowning is not fun.
Thanks for any advice,
Bill
Bill
- BigJohnT
- Thank you received: 1176
06 Nov 2013 20:28 #40580
by BigJohnT
Replied by BigJohnT on topic Time to jump in the water.....
Bill,
Welcome to the forum, if you take things one bite at a time you won't drown...
JT
JT
- cncbasher
- Thank you received: 288
06 Nov 2013 21:08 #40583
by cncbasher
Replied by cncbasher on topic Time to jump in the water.....
Welcome to linuxcnc Bill .
dont worry there are plenty of us with Lifebelts to throw in your direction .
take a good look around and get comfortable then just ask any questions that your unclear at etc
i would suggest you look at JT's pages at www.gnipsel.com, and in particular his 7i77 tutorial , along with his BP conversion files etc , but no doubt you have already been
pointed in that direction
- Thank you received: 4966
06 Nov 2013 21:18 #40585
I think I would suggest starting with the engraver, as it is least critical and will get you used to the process. Your second conversion is likely to work a lot better than your first.
It took a few iterations to get my lathe/mill combo working. You don't want to be trying to decide whether to make parts or upgrade the CNC of a working machine.
Replied by andypugh on topic Time to jump in the water.....
- willysnowman
07 Nov 2013 02:43 #40600
by willysnowman
Yeah, I use the lathe several times a week. It would be tough to be without it for a week. I forgot how I was able to get by without one? On the other hand, it would be great to have it CNC. There are lathe jobs I pass up because of no CNC. I just design my own stuff simpler which is actually a benefit of manual lathe. You find ways to simplify the manufacturing. It just does not look as bling.
I will have to do a little more planing and compare cost and time.
Replied by willysnowman on topic Time to jump in the water.....
- willysnowman
07 Nov 2013 14:48 - 07 Nov 2013 14:49 #40621
by willysnowman
Last edit: 07 Nov 2013 14:49 by willysnowman. Reason: added pic
- cncbasher
07 Nov 2013 15:43 - 07 Nov 2013 15:44 #40622
by cncbasher
yes you have that correct Bill ,
but just to clarify a few points , the breakout board for steppers is a 7I76 and for servos is a 7I77
if i may suggest go for Leadshine stepperdrivers or geko's ) rather than the all in one chinese drives , far more reliable
and of course you dont have the problem if one drive packs up they all do ! .
it actually makes it easier to setup and control .
if you use these across the board it will make it easier to swap out in times ( hopefully not ) of any problems
also go for the drives and power supplys capable of 48v - 60v rather than the 12 - 24v range
and where needed a 12 - 24v supply for contactors or low volts relay switching
p.s glad your using solidworks ! , i have hsmworks also
although i tend to use camworks more often
Dave
Dave
Last edit: 07 Nov 2013 15:44 by cncbasher.
The following user(s) said Thank You: willysnowman
- jimmy111
08 Nov 2013 10:02 #40654
by jimmy111
Replied by jimmy111 on topic Time to jump in the water.....
There are lots of free apps too. Here are a few
www.hongkiat.com/blog/25-free-3d-modelli...you-should-not-miss/
And mesh cam is a decent freeform cam app for $250 or so.
No reason to break the bank before you decide this is for you or not.
But really you should buy a book and learn to program your own. Its not that hard and your programs are much more controllable and SMALLER than any cam produce would produce for you.
- willysnowman
09 Nov 2013 01:43 #40676
by willysnowman
Thanks for the info.
I have been using SW since '97 and already own a copy so no money spent. I tried others an quickly give up. I am too entrenched.
The HSMWorksExpress is a free program. It actually works pretty well for what I do (2.5D). I would highly recommend it. I do have to change my code every program since I do not have a Z. I also have been modifying them because of my lack of knowledge of HSMWorks, but I am doing this less and less.
I have read the "CNC Cookbook" (book not website) many times. I would recommend this as an easy read with a good general overview.
For me, it is a matter of improving my business. I already know I love machining. I just need to make the machines which fit in my basement more productive.
Bill
Bill
- willysnowman
10 Nov 2013 08:22 #40696
by willysnowman
Replied by willysnowman on topic Drowning in alphabet soup
I started to pick a computer this morning. I thought I would just search for what others are using and copy. I keep finding most of these CPUs/motherboards from just this year are obsolete.
I have found the latency list: wiki.linuxcnc.org/cgi-bin/wiki.pl?Latency-Test Do I sort this by least max, jitter and go from search for a source for the top ones?
A lesser option would be to buy one and run a latency test. If it is no good, ship it back. Is this SOP? I have a small list of some which may work??
I guess this also would be a good time to at least think about my power supplies and communications. This will be a stand alone computer dedicated to linuxcnc. I will need a way to talk to it (transfer G-code files) with my windows computer. I will also need a way to control linuxcnc at the machine (touchscreen,joystick, computer keyboard?).
I am sure this will become clearer as time goes on, but it would be good to have it included in my power supplies spec. I would like to go MicroATX or smaller, but size is not a driving issue except on engraver.
Time to create page: 0.274 seconds
