Strange position/offset problem
- staviq
30 Oct 2014 20:32 #52580
by staviq
Strange position/offset problem was created by staviq
Hi.
I would appreciate if anyone could help.
I have this strange problem with homemade xyz l297/l298 based cnc table.
In AXIS window / MDI tab i issue following g codes:
G0 X100 Y0
G0 X0 Y100
G0 X0 Y0
And the problem is table does not end in the same position it started ( stops with about 4mm offset in X and about 45mm offset in Y ).
BUT ( the strange part )
If i issue previous g codes backward:
G0 X0 Y100
G0 X100 Y0
G0 X0 Y0
Table does go back to exactly where it started ? It is impossible, i think, that table is losing steps, because when going backward it would have to do extra steps to cancel the offset ?
My head is currently in a wtf state, any ideas ?
Thanks in advance, and Best Regards.
G0 X100 Y0
G0 X0 Y100
G0 X0 Y0
G0 X0 Y100
G0 X100 Y0
G0 X0 Y0
- Thank you received: 4967
30 Oct 2014 20:34 #52581
What is the result with a 50mm move?
Is it possible that the scales are just incorrect?
Replied by andypugh on topic Strange position/offset problem
- staviq
30 Oct 2014 21:00 - 30 Oct 2014 21:02 #52584
by staviq
Replied by staviq on topic Strange position/offset problem
If it would be a scale problem, going from 0 to 100 and back to 0 should still go back to where it started anyway.
For 50mm move offset is about 2mm X and 15mm Y.
Lead screw pitch is 1.75mm, maybe its some kind of floating point error accumulation problem ?
Last edit: 30 Oct 2014 21:02 by staviq.
30 Oct 2014 21:19 #52587
It doesn't sound like a scale issue.
Internally the step count accumulators are all integers.
Can you tell if the X100 Y100 point is the same for both right-hand and left-hand triangles? (ie, is the problem on the way there, or the way back)
The difference seems that it might lie in the direction of the move when both axes are moving.
Could you try a right-hand and left-hand square, ie the same sort of pattern but only moving one axis at a time.
I am wondering about cross-talk between step/dir channels on combined moves, or possibly very marginal power supply to input opto-isolators.
Sorry, I misread the problem description.If it would be a scale problem, going from 0 to 100 and back to 0 should still go back to where it started anyway.
No, if it was that then the problem would have been spotted by other users, surely?maybe its some kind of floating point error accumulation problem ?
- staviq
30 Oct 2014 23:03 - 30 Oct 2014 23:05 #52590
by staviq
Going from X0 Y0 straight to x100y100
"G0 X100 Y100"
works correctly ( and then G0 X0 Y0 works also correctly, going back to where it started ).
Going from X0 Y0 to X100 Y100 in two moves:
G0 X100 Y0
G0 X100 Y100
incorrectly ends up in about X62mm Y100mm real world position,
then, going back
G0 X0 Y0
incorrectly lands at about X-38mm Y0mm real world position.
Going in 2 steps but the other way around gives the exactly the same incorrect positions ( X and Y error is NOT inverted ).
Basically 1 gcode works fine, 2 gcodes works incorrectly, the error is reproduceable, and not exactly random.
"G0 X100 Y100"
G0 X100 Y0
G0 X100 Y100
then, going back
G0 X0 Y0
Last edit: 30 Oct 2014 23:05 by staviq.
30 Oct 2014 23:10 #52591
If you move a "fast" axis and a "slow" axis both at the same time, then the "fast" axis will be slowed down to match.
Is it all possibly that one of your axes has a much higher (too high) acceleration value?
- staviq
31 Oct 2014 00:14 #52594
by staviq
All axes have the same speed and acceleration and its set really slow at 2mm/s 3mm/ss
31 Oct 2014 01:19 #52596
What happens if you comment out the X step/dir lines in HAL, so that LinuxCNC only _thinks_ it is moving the axes?
(then try the same thing for Y)
- staviq
31 Oct 2014 05:35 #52604
by staviq
I think i'm gonna borrow an oscilloscope from work tomorrow and count parallel port pulses to verify for sure whether it's software or hardware issue, since it seems to me like there is no easy answer and the problem is indeed strange at least.
- staviq
01 Nov 2014 08:54 #52640
by staviq
Well,
Pulses are being emitted correctly from software and hardware, and the motor driver step and direction pins connected directly to parallel port pins gives me twice the possible speed and 100% real world position accuracy, ergo it has to be breakboard's fault.
This does not explain non random errors, however if without optocouplers everything works perfectly it has to be optocouplers, so it's time to make better breakout board.
Anyway thanks a lot for help and more or less consciously getting me on the right track, without it i would drown looking for source in configuration files
Time to create page: 0.080 seconds
