MDI Commands
- doronby
13 Jan 2015 22:29 #54974
by doronby
Re:Probe for center of hole was created by doronby
Can you please point me to where I can follow a newbie step-by-step instructions on how to have a one button on GUI execute this code or any pre-define G-code from a file
thanks
-Doron
thanks
-Doron
- Thank you received: 1471
13 Jan 2015 23:49 #54977
Replied by Todd Zuercher on topic Re:Probe for center of hole
This is about as succinct an explanation as I can find.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding_Custom_MDI_Buttons
It would also help to read as much info you can find on Halui and Pyvcp in the integrators manual.
If you search around you should be able to find more examples to try to follow..
The following user(s) said Thank You: doronby
- dgarrett
- Thank you received: 297
14 Jan 2015 02:27 #54985
by dgarrett
Replied by dgarrett on topic Re:Probe for center of hole
Another alternative to experiment with is a set set of probe
routines adapted for ngcgui:
(This complete simulator config will work for 2.6 or greater,
set up is for inch units)
The simulate_probe is a simple built-in gui to simulate a probe
$ wget http://www.panix.com/~dgarrett/stuff/probe_demo.tgz
$ tar zxf probe_demo.tgz
$ cd probe_demo
$ linuxcnc probes.ini & # & --> run in background
$ simulate_probe &
- doronby
14 Jan 2015 10:24 #54990
by doronby
Replied by doronby on topic Re:Probe for center of hole
I see that the use of MDI_COMMAND requires editing the INI file and is limited to 63 lines. (and having to restart the engine,,,)
I was hoping to be able to use several buttons which are connected to G-Code files. (typicallly for Z-touch off, center probe, special tool offsets, etc....)
Thanks.
-Doron
Thanks.
-Doron
- Thank you received: 4648
14 Jan 2015 21:00 #55002
You can have 63 buttons. That doesn't seem like such a limitation.
Each button can call a G-code subroutine of arbitrary length.
You can do much the same thing without INI and HAL intervention by using a GladeVCP button linked to an MDI_action object. The MDI_action contains a single line of G-code, but that too can be a subroutine call. Rather usefully the MDI_action string can contain string-substitution values from other GladeVCP controls, and those can be passed as parameters to the G-code subroutine.
Replied by andypugh on topic Re:Probe for center of hole
- doronby
15 Jan 2015 01:01 #55008
by doronby
What I really need a step by step 'Newbie' how-to connect GUI button to arbitary G-code.
Does anything like that exist ?
If not, I guess I will have commence the long reading + Trial-and-error exercise.
-Doron
P.S.
So far I have done the following.
1) Installed the LiveCD
2) Run the step wizard and configure the pins and screws
3) Modify the files to use the x and y screw compensation files I created with my DRO
4) Adjust speeds, accelation and travel limits to fit my machine.
4) Adapt Z-Touch-off and Center-Finder G-code that I found on the Forum.
5) Since I had modified my setup files... I can not re-run the StepWizard again to activate options as it warns me that I am going to loose my hand edits...
-Doron
P.S.
- doronby
15 Jan 2015 01:04 #55009
by doronby
not 63 buttons.... total of 63 lines with MDI_Command..0..63
15 Jan 2015 01:43 #55012
No, each MDI_COMMAND HAL pin calls a single line of G-code defined in the INI file.
If you need more than one line of G-code then the single line of G-code has to be a subroutine call.
eg
MDI_COMMAND O<hole_probe> CALL
MDI_COMMAND O<bottom_left_corner> CALL
eg
- Rick G
- Thank you received: 114
15 Jan 2015 16:12 #55022
by Rick G
Replied by Rick G on topic Re:Probe for center of hole
- BigJohnT
- Thank you received: 994
15 Jan 2015 20:43 #55025
by BigJohnT
Replied by BigJohnT on topic Re:Probe for center of hole
Where does it say the limit is 63 commands?
BTW 0-63 is 64...
JT
BTW 0-63 is 64...
JT
