Thinking of moving from Mach3 to Linuxcnc
- beefy
- Thank you received: 57
11 Jul 2015 08:03 #60553
by beefy
Thinking of moving from Mach3 to Linuxcnc was created by beefy
I've been working on my own Mach3 plasma system and external torch height controller which will communicate with Mach3 via Modbus. Will also add in a remote pendant using Modbus.
However, I'm seeing the gradual demise of Mach3 in the future. You need XP and an old (= unreliable) parallel port PC. I've heard Mach doesn't work too good on modern PCs, so even if you can get a parallel port card, that may not be a long term solution.
This is what I can do with Mach3 and my main question is can Linuxcnc do the same:
1. Screen customisation - adding DROs, buttons, LEDs. I've heard this is a lot of work in Linuxcnc, true ? In Mach I can use images to enhance the appearance of the various elements.
2. Scripting - Mach uses Cypress Enable (Basic) to write macros/scripts which you can use for all sorts. For example, I can create whatever DRO, buttons, etc I want then use macros to read DRO values, save them to a "profile" file, etc. Then I use another button with a macro attached to display a dialog box on the screen with a list of all the profile files. I choose one of these profile files, press the OK button, and the DROs are updated with all the parameters.
3. Modbus serial communication - certain parameters in the DROs are then passed to the torch height control, while at the same time Mach is reading parameters from the external torch height control and remote pendant, and using those parameters to say update other DROs.
Also does Linuxcnc use more modern PCs. I'm noticing the recommended (for Mach) Pentium 4 PCs are getting harder to find and that is going to get worse with time. I know Linuxcnc uses Mesa cards, but do you ALSO need a parallel port computer, or can the Mesa cards take their place.
Cheers,
Keith.
Cheers,
Keith.
- Thank you received: 1464
11 Jul 2015 09:02 #60554
Replied by Todd Zuercher on topic Thinking of moving from Mach3 to Linuxcnc
Building custom guis is difficult if you are unfamiliar with computer programing (or are unwilling to learn).
Linuxcnc does work well on some modern hardware. But the hardware needs to be able to provide adequate latency. A good example of hardware that doesn't work would be a typical laptop that is so burdened by hardware interups because of all the power saving features. It is a little bit of a crap shoot picking out a board, but it is mainly dependent on the motherboards design.
Linuxcnc isn't dependent on the parallel port, but it is a convenient and cheap means for real time i/o for software access. Other options like many cards from Mesa, have the added benefit of adding hardware counters, and step generation making them vastly superior to the lowly parallel port.
- beefy
11 Jul 2015 09:16 #60555
by beefy
Replied by beefy on topic Thinking of moving from Mach3 to Linuxcnc
Thanks Todd,
ha ha, all I ever seem to be doing is learning stuff. I'm one of those guys who gets irritated with people who just say, "Can you do this for me, I don't know how", instead of asking, "Where can I find information on learning this".
Perhaps I've just had my very first taste of computer programming with VBA style dialog boxes and file creating, opening, etc. Prior to that I've learnt a bit of C for programming Arduino, a quite useful tool. So what type of computer programming is needed for Linuxcnc gui customisation ?
Mach3 was also a bit of try it and see regarding PCs. For example the last one I tried had perfect specs yet gave a bad driver test. Other less powerful PCs have had much better stability.
Keith.
Keith.
- BigJohnT
- Thank you received: 1176
11 Jul 2015 14:04 #60558
by BigJohnT
Replied by BigJohnT on topic Thinking of moving from Mach3 to Linuxcnc
I need to add that adding custom buttons and stuff is easy. Easy is limited to pyvcp. Anything can be done with open source but takes some effort.
JT
JT
- WillyInAus
12 Aug 2015 16:11 #61319
by WillyInAus
Replied by WillyInAus on topic Thinking of moving from Mach3 to Linuxcnc
Beefy Beefy Beefy we have go to stop meeting like this
Just do it,
Just do it,
- Thank you received: 4967
12 Aug 2015 22:02 #61339
Custom GUIs tend to use Glade (either based on the all-Glade G-screen, or as embedded tabs in non-Glade GUIs.)
Any background coding with Glade tends to be in Python.
An example of an (ugly) embedded tab is here: wiki.linuxcnc.org/cgi-bin/wiki.pl?Hobbing
If you open the zip file you can inspect the hobbing.py that has the background code that updates the onscreen values when gear parameters change.
Info on customising Gscreen is here:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Gscreen_Customization
And the special HAL-aware controls that can be used:
www.linuxcnc.org/docs/html/gui/gladevcp.html
Replied by andypugh on topic Thinking of moving from Mach3 to Linuxcnc
- beefy
13 Aug 2015 07:13 - 13 Aug 2015 07:24 #61361
by beefy
Thanks John & Thanks Andy (some good links are always welcome).
That screen at the bottom of the Gscreen page looks just like something made in Mach3. Ha ha, a bit of a closer look and I see the words Mach3 at the top. That must be the base image they used. Not sure if I'm into the old wood paneling mind you
It certainly is a whole new ball game going to Linux from Windows, plus I'm finding the info on Lcnc seems to be much harder to find. I don't think this transition will happen overnight.
Hi Willy, I think the cnc plasma world is fairly small so we'll probably bump into each other in various places. Pity we didn't live near each other. You live where I originally intended to go when I came to Australia (I'm a pom, hope you don't mind LOL).
Keith
Keith
Last edit: 13 Aug 2015 07:24 by beefy.
- Thank you received: 2159
13 Aug 2015 07:56 #61364
Replied by cmorley on topic Thinking of moving from Mach3 to Linuxcnc
That Gscreen sample is an image from Mach3 - it's not included because i imagine the image is not open source.
If you know of a screen image that is open source please let me know.
The problem with using image files for the main background is it requires the screen to be a certain size.
resizing moves the buttons around.
using gladevcp/gscreen (or gmoccapy) for a screen is easier then trying to modify AXIS but still requires
a fair investment if you want something very different.
If it;s just a few buttons and suck then it is pretty easy.
Chris M
Chris M
- beefy
13 Aug 2015 11:49 #61371
by beefy
Thanks Chris,
that's interesting about the background and the buttons, etc not being "locked" to each other. I don't think that happens in Mach so I would have wrongly assumed it would be the same in Lcnc. Wish there was a decent graphical screen designer for Lcnc, I'd happily pay for it.
Regarding open source images for screensets, what about the free ones being offered for Mach. See this page:
www.machsupport.com/software/downloads-updates/screensets/
I'm sure if there's any licensing requirements for any of them it will be mentioned in the downloaded material. You can just go into the bitmaps folder in the downloaded screenset and look at all the images with a picture viewer.
I'm sure a Google of Mach3 screensets may come up with some additional ones.
Hope that's of some use.
Keith
Keith
13 Aug 2015 16:39 #61377
I think it is possible, but some work, to have the placement of widgets relative to the main window size, so that re-sizing the image keeps the widgets in the same relative position.
Time to create page: 0.066 seconds
