New to LinuxCNC - seek ATC advice
11 years 2 months ago #61320 by andypugh
ftree wrote: With a low latency PC what frequency can I expect to drive stepper motors?
I think the limit is something like 10MHz. Basically so fast that you don't even have to consider it.
11 years 2 months ago - 11 years 2 months ago #61321 by ftree
Excellent. I only need ~ 250Khz max. My stepper has 6400 steps per rev with 8mm lead screws. So 2000 rpm = 16m/min rapids @ 214Khz.
Last edit: 11 years 2 months ago by ftree.
11 years 2 months ago - 11 years 2 months ago #61408 by ftree
Andy,
I've had a quote back for MicroE Systems Mercury II.
The SPI or Quadrature sensors are around £750+VAT on a 5m cable. 3m of tape with end limits is around £400+VAT. The end limits laser etched on the tape are useful.
The Quadrature version has some useful pins like tri state alarm and active-low non latching for the limit markers. At 40nm interpolation and a max speed of ~20m/min we would require a output frequency of around 2MHz.
The resolution for the SPI version @ 25Mhz does not drop off with speed.
Pricey. Does anyone know how that compares to Renishaw Resolut?
11 years 2 months ago #61409 by andypugh
ftree wrote: Pricey. Does anyone know how that compares to Renishaw Resolut?
You could look at magnetic tape scales:
www.machine-dro.co.uk/digital-readout-sy...30&encoder_type=1101
That works out at about £170 for the tape and £70 to £170 for the reading head depending on accuracy.
I think that most machines choose to trust the ballscrews.
10 years 7 months ago #72007 by tkamsker
hi ftree did you solve yours i just saw you mentioned my video ;)-
thomas
Time to create page: 0.182 seconds
