Stepconf works but Axis dont move - Speed Error
- Kolbi
27 Sep 2015 19:42 #63061
by Kolbi
Stepconf works but Axis dont move - Speed Error was created by Kolbi
Hi EMC-Fans,
Maybe somebody can help me with a Problem.
I built a belt driven Machine which drives 300mm/s with 2000 acceleration on XY without Problems, but when i increase the speed of the leadscrew Z-Axis above 12mm/s, all axes dont move anymore in Axis/Main Program.
In Stepconf Z works up to 20mm/s, this is slight above 20khz, this seems to be the max frequency of my stepper driver octocouplers. Step Pulses are 10000ns, Jitter 10000, gives me max 25khz step frequency from pc.
So it should work, but it doesnt, tried several things like inverting and changing pins, manual enable, increasing voltage for octocouplers to 6V (this solved the direction error on Y axis i had sometimes), etc...
Nothing seems to work, i think its some kind of limitation in the program i dont know.
If i reduce microstepping on Z, i can drive faster, but less torque and loosing steps.
Here my actual working config:
Z-Axis:
Steps: 400
Micro: 8
Transmission: 1:1
Leadscrew: 3mm
Max Speed: 12mm/s
Max Acc: 1000mm/s
Time to max Speed: 0.0120s
Distance to max Speed: 0.0720mm
Max Step Frequ.: 12800Hz
Steps/mm: 1066.7
It seems that 12mm/s = 12800Hz is the limitating factor, if i go above, nothing works anymore (except Stepconf), i hope somebody can help
Greetings from Austria, and sorry for my bad english
Z-Axis:
Steps: 400
Micro: 8
Transmission: 1:1
Leadscrew: 3mm
Max Speed: 12mm/s
Max Acc: 1000mm/s
Steps/mm: 1066.7
- cncbasher
- Thank you received: 202
28 Sep 2015 00:39 #63074
by cncbasher
Replied by cncbasher on topic Stepconf works but Axis dont move - Speed Error
a few questions ?
what stepper drivers are you using ?
and what voltage is your power supply and current rating ?
the chance is your trying to run the steppers faster than they are capable in your velocity ratings , along with the incorrect step timings
Step Pulses are 10000ns, Jitter 10000 ( this at first glance is incorrect )
are you using a laptop ?
increasing voltage to drivers will damage the parallel port , at some stage so beware
are you connecting the positive of your opto to 5v and the neg side to the parrallel port ?
so sinking the current rather than sourcing , is far better
steps should be set at 200 not 400 , so check this
check your axis for any mechanical binding , on the leadscrew
- Kolbi
28 Sep 2015 00:47 #63075
by Kolbi
Replied by Kolbi on topic Stepconf works but Axis dont move - Speed Error
Why is 10000ns Jitter incorrect? Jitter Test shows about 8000 max Jitter.
400 Steps are correct, its a 0.9° Nema23. Hardware Setup is correct, everything works with 12mm/s Z-Speed.
I use a octocoupler Board, and can drive Z up to 21khz in Stepconfig, but why not in the Main Program?
- Online
- Thank you received: 5281
28 Sep 2015 01:36 - 28 Sep 2015 01:58 #63081
Replied by PCW on topic Stepconf works but Axis dont move - Speed Error
Are you using the stepgens reset feature?
if all three axis have 10 usec step pulse widths and you use the reset feature you are very close
to running out of time at 20 KHz step rate (since the CPU stalls for the entire pulse width and this could happen
on all three axis)
What base thread period are you using?
Your acceleration is pretty fast ( 12 ms to full speed ) might try lowering that
on all three axis)
Last edit: 28 Sep 2015 01:58 by PCW.
- Kolbi
28 Sep 2015 01:42 #63082
by Kolbi
I dont know what the stepgen reset feature is!?
I use the German GUI, is base thread period the number above Max Step Frequency? Then its 20000ns.
Reducing Acceleration did not work
- Online
28 Sep 2015 02:01 #63084
20000 ns is pretty fast
You might increasing the period to 30000 ns or so and see if that helps
It could be that you are just running out of I/O cycles, especially if this is a motherboard parallel port
- cncbasher
28 Sep 2015 02:11 #63086
by cncbasher
their are a number of reasons we as moderators ask questions that new members may think are not part of the problem,
to eliminate common problems .
have you changed the max velocity settings in your ini file , they are set by default at a low speed , by stepconf
perhaps you could archive your config and attach
- Kolbi
02 Oct 2015 17:36 - 02 Oct 2015 18:07 #63363
by Kolbi
Thanks for the help so far, here is my config:
# Erstellt von stepconf am Mon Sep 28 21:23:52 2015
# Änderungen an dieser Datei werden beim nächsten
# Aufruf von stepconf überschrieben.
The Base Period is much higher than 10000, lowering it to 10000 did not work. Maybe you have some ideas what to do?
[EMC]
MACHINE = Tsegi1
NML_FILE = emc.nml
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc/emc2/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = emc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 36057
SERVO_PERIOD = 1000000
[HAL]
HALFILE = Tsegi1.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 25.00
MAX_LINEAR_VELOCITY = 250.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 250.0
MAX_ACCELERATION = 2000.0
STEPGEN_MAXACCEL = 2500.0
SCALE = 32.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 710.0
HOME_OFFSET = -3.000000
HOME_SEARCH_VEL = -20.000000
HOME_LATCH_VEL = 15.625000
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 1
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
SCALE = 39.2156862745
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 750.0
HOME_LATCH_VEL = 12.750000
HOME_SEQUENCE = 2
[AXIS_2]
TYPE = LINEAR
HOME = 80.0
MAX_VELOCITY = 12.3502371246
MAX_ACCELERATION = 1000.0
STEPGEN_MAXACCEL = 1250.0
SCALE = 1066.66666667
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = 0.0
MAX_LIMIT = 80.001
HOME_OFFSET = 83.000000
HOME_SEARCH_VEL = 5.000000
HOME_LATCH_VEL = -0.468750
HOME_SEQUENCE = 0The Base Period is much higher than 10000, lowering it to 10000 did not work. Maybe you have some ideas what to do?
Last edit: 02 Oct 2015 18:07 by BigJohnT. Reason: add code tags
- Kolbi
09 Oct 2015 17:39 #63607
by Kolbi
Does anybody have an idea what i could try?
- cncbasher
09 Oct 2015 17:58 #63608
by cncbasher
This is incorrect :
reducing microstepping will increase torq
ok please attach your full config as an archive to this post , and please give us this information
what stepperdrives you are using
what stepper motors ,
what voltage & current rating is your power supply
are you using ballscrews or threaded rod , and are they driven directly or via a belt drive
it seems you are driving the axis at a higher velocity than it is capable of , z axis shows this as missing steps , and always in the downward direction .
this also can be attributable to not having an adequate power suppy , under demand conditions
