- Thank you received: 202
With the 7i76, which is a dedicated step/dir board, yes. But there are many other options. The 7i77, for example, is designed to drive servos by analogue voltage command. Old-school but very effective inside a feedback loop.BishopCNC15 wrote: I looked into the Mesa Electronics boards. So if I use a 5i25 and 7i76 then my PC will still be communicating with my drivers with step+direction right? I've heard there's a bandwidth limitation doing things like this.
Since the budget is fairly high, what about EtherCat or something similar?
lerman wrote: As far as I can tell, High Speed Machining involves high speeds and high accelerations. Cutting forces are relatively low because of small tool diameters and high spindle speeds, but acceleration forces are high
BishopCNC15 wrote: We have ordered a Tormach PCNC 770 mill. It should be arriving in the next month or so. We just received a mesa 5i25. We will be using LinuxCNC as a starting point. Right now I need to source a good PC for running linuxCNC.
