cutter comp
11 years 1 day ago #64550 by dsb1
cutter comp was created by dsb1
is there cutter comp in linux cnc like machining centers use,which have a tool registry,where you enter tool diameter or radius imformation
the way I am running if I interpolate a hole and its to small, I have to write a new program with a larger hole diameter HELP!!!!!!!!
