Spindle synchronized motion with gear
10 years 11 months ago #66151 by REEEN
Hello Community,
I have a customer machine here with a servo driven spindle with 2 gear stages.
There is a TTL encoder on the spindle with a, b and a index pulse.
I want to use the encoder on the spindle motor to provide spindle synchronous movement, which is normally no problem, but the gear is providing me headache....
I can easily multiply the encoder scale according to the current gearstage, but the index pulse will come on every full revolution of the motor, which is not a full revolution of the spindle because of the gear.
I think the index pulse is important to be there on a full revolution for spindle synchronized movements.
Can somebody tell me how to solve that problem ?
I have already thought of a comp that will trigger the a fake index on every full revolution of the spindle, but I'm not quite sure whether this works.
I don't worry about the backlash in the gear because it is nearly nothing and doesn't matter at all.
Thank you guys!
Greets Rene
10 years 11 months ago #66154 by cmorley
add a index sensor somewhere outside of the gear train - like a prox switch.
use the AB from encoder and the index from the added sensor.
Just another idea
Chris M
10 years 11 months ago #66157 by REEEN
I just thought about that, but my customer is far away...
Just for confirming, can I use a fake index ?
I would do it like so:
First index Signal will be real index and the following will be emulated by a comp according to the gearstage.
10 years 11 months ago #66161 by cncbasher
10 years 11 months ago #66163 by REEEN
Okay, now I understand it!
The index pulse is used to place the thread cutter on the spindle in the right position, so if you cut a thread miltiple times you will be in the exact same path.
I don't have a index that comes once on a turn so I cannot say whether the position of the thread cutter is right.It is like having multiple reference switches so you don't know where you are.
My customer does only need spindle synchronized motion to cut threads without special toolholders on its mill, so this is no problem!
It would be a problem on a lathe with multupass threads or milling threads with a special tool.
I think I can use the normal index pulse as it is only used once. And it does not matter where.
Am I right ?
Greets Rene
10 years 11 months ago - 10 years 11 months ago #66165 by PCW
It depends... the index is not used just once but at the start of every threading pass
If your index happens at a integer multiple of spindle turns (say every 2 or 3 spindle turns), it would work
if not, it will not work because the threading passes will start at different angular positions of the spindle
Last edit: 10 years 11 months ago by PCW.
Time to create page: 0.109 seconds
