LinuxCNC 2.7.3 Trajectory Planner, circle problem
04 Jan 2016 08:39 #67805 by matiq05
Hello, i have little problem with new trajectory planner in LinuxCNC 2.7.3. When i start gcode with circles, like this:
Warning: Spoiler!
I need do it fast, but circles are made in 2 steps...
Machine starts circle fine but slow down when reach second point, and start accelerate again to first point of circle. I try use G64 Pxx Qxx but it's not help. Always the same thing... 2 stepc circle.
Somone tell me what is wrong ? In INI file i add new trajectory planer options:
Warning: Spoiler!
And experiment with all, but still bad :(
Please help
04 Jan 2016 10:59 #67811 by andypugh
It is possible that your machine acceleration limits are the problem.
What are your velocity and accel limits in the INI file?
04 Jan 2016 11:40 #67812 by matiq05
Hmm in INI file i have only set MAX_VELOCITY and DEFAULT_VELOCITY, i will try with accel, but when in gcode circle have manny points then machine work correcly
04 Jan 2016 15:25 #67836 by andypugh
The acceleration is a per-axis setting. But if short segments work then it probably isn't that.
05 Jan 2016 07:41 #67908 by Rick G
Tried the original code which has a G64 on a sim and it shows the slow down you reported.
However edited the file with G64 P.05 Q.05 and did not see slow down.
Rick G
05 Jan 2016 08:43 #67910 by cncbasher
what cam program are you using ? , this is a common problem .
05 Jan 2016 10:14 #67914 by matiq05
This is my INI file:
Warning: Spoiler!
I try with G64 P.05 Q.05 and same problem...
And one strange thing, second part of circle machine make faster than first
05 Jan 2016 12:05 #67916 by andypugh
You have F55000 or 55m.min / 0.9 m/s
Acceleration in a circular path is v^2 / r,
16.8m/s^2 for a 50mm arc
8.4m/s^2 for a 100mm arc
4.2m/s for a 200mm arc
Your machine acceleration limits are 3m/s^2 for each axis.
Working the other way, you would expect a velocity of
23m/min at 50mm radius
33m/min at a 100mm radius
46m/min at 200mm radius.
Is this what you are seeing?
05 Jan 2016 12:15 #67917 by matiq05
Acceleration and velocity is good but why machine must stop on point and start again accelerate ?
05 Jan 2016 12:59 - 07 Jan 2016 07:20 #67919 by matiq05
Hmm.. i write my own circle in g-code and copy g-code with circle from previous code i upload here and for some reason it's work.. Circles are make fast as machine can, no stop, all in max speed. Why ??
This is code:
Warning: Spoiler!
/edit
I have new information/problem. So, i have this code:
Warning: Spoiler!
This code have like you see 3 circles. This g-code run fine, machine run fast on arc and i like it. But this all circle is make on Z-5, and when i add in Gcode before circle Z10, like this:
Warning: Spoiler!
Then last circle is run in 2 steps like before... WHY ?? What is wrong ?
Last edit: 07 Jan 2016 07:20 by matiq05. Reason: new info
Time to create page: 0.523 seconds
