XFCE screen rotate only choice normal
10 years 8 months ago #69771 by jaro_p
It is this problem only for non-free driver, or both drivers free and non-free?
10 years 8 months ago - 10 years 8 months ago #69788 by Amedee
AFAIK the Intel drivers are open source, there is no 'non-free' version
Last edit: 10 years 8 months ago by Amedee.
The following user(s) said Thank You: jaro_p
10 years 8 months ago - 10 years 8 months ago #69825 by jaro_p
Thank you for your responses. I decided to buy an inexpensive card from NVIDIA and this solve the problem.
Last edit: 10 years 8 months ago by jaro_p.
10 years 8 months ago #69826 by Amedee
If I were you, I would first try with Debian Jessie to see if it is solved there -- it takes 10 minutes ;)
You can download a Debian 'Live CD' from here (choose 'debian-live-8.3.0-i386-mate-desktop.iso' from the list). This will allow you to test without touching what you already have.
Choose 'Live (686-pae)' from the menu.
If it works, then it is probably worth going for it.
(LinuxCNC uses the RTAI kernel, not the one from Debian, but the version are about the same)
Going to NVIDIA might be a solution as well, but it also may screw up your latency -- from what I have read in this forum, NVIDIA cards are not always good candidates for low latency.
10 years 8 months ago - 10 years 8 months ago #69861 by jaro_p
It works, what can I do?
10 years 8 months ago - 10 years 8 months ago #69863 by jaro_p
Time to create page: 0.504 seconds
