Helping HAL file programming
10 years 8 months ago #70268 by vuquangtam
hello, i want to create my own configuration file (HAL) by text editor. where can i find documents to learn ? do HAL files have any flowchart to follow ? thank you
10 years 8 months ago #70273 by cmorley
www.linuxcnc.org/docs/2.7/html/hal/tutorial.html
There are more docs for linuxcnc too
There are no flow charts for HAL files.
When you say your own configuration files do you need to build an INI file too?
Chris M
The following user(s) said Thank You: vuquangtam
10 years 8 months ago #70276 by vuquangtam
thanks for your reply. I studied from " www.linuxcnc.org/docs/2.7/html/hal/tutorial.html ". i want to create both ini and hal files. how i can get the rule to make files as below : " github.com/machinekit/machinekit/tree/9e...nfigs/ARM/BeagleBone ". i read document you've suggested but i can't get the rule. Which is the best method to get that rules.
10 years 8 months ago #70279 by cmorley
Ahh beaglebone.
Linuxcnc does not support the beaglebone in any released branches.
machinekit does so I would check their docs but I know the docs are very sparse.
This forum caters primarily to linuxcnc.
Obviously there is overlap but not in this case :(
Chris M
Time to create page: 0.214 seconds
