Login issues
10 years 8 months ago #70842 by JJBrew
Login issues was created by JJBrew
Login issues I just loaded the newest EMC from this site it loaded up okay but when I went to log in at the start up it keeps on saying incorrect password. I have reloaded it twice now still the same I can use all the help I can get.
10 years 8 months ago #70845 by Todd Zuercher
Replied by Todd Zuercher on topic Login issues
Pay close attention to what the login screen says. First it prompts for your user name, then password on the next screen. If you enter the password on the first screen you'll never get in. (You aren't the first to make this mistake.)
10 years 8 months ago #70852 by JJBrew
Replied by JJBrew on topic Login issues
Yes you right I have been at first I did do it wrong but when I figured out what I was doing I started to do name then password ,but still saying wrong password. Thinking I have to change the password at the root
10 years 7 months ago - 10 years 7 months ago #70886 by JJBrew
OK guys I went into the root directory and change the password for the name I used I sync it and then I rebooted as per se reboot went to re-login same thing I used my name is it required and the password I gave it when I changed it inside the root directory . It keeps on coming up as incorrect password I'm at a loss here guys I'm going to try read loading windows in the system because for some reason the CD I downloaded will not do auto install from the DVD that I have as a external drive.
OK update reloaded windows On to the system I was able to reload the program and got it to work going to take some time to learn this one. It would be fun for sure lots of reading time for use. Thank you for the replys
Last edit: 10 years 7 months ago by JJBrew. Reason: Update
10 years 7 months ago #70928 by JJBrew
OK load it all up fine like I said I clicked on the screen to open up the appropriate folder for CNC and I noticed I am missing one subfolder am I supposed to load it off of the live CD or have I missed something enclosed is a copy of the photo I took of my screen
10 years 7 months ago #70960 by Todd Zuercher
I don't see what you are missing. Those are the same choices under CNC that I have. Except "Linuxcnc Config Picker" is just called "Linuxcnc" on mine. Do you know what it is that you think you are missing? If you are talking about missing the linuxcnc directory in your home folder, that will be created automatically the first time you run the config picker and choose a sample config, or run one of the setup wizards.
Time to create page: 0.362 seconds
