Error while loading file
10 years 7 months ago #71401 by andypugh
Replied by andypugh on topic Error while loading file
gizmo6023 wrote: Thanks, I will take a look at the tolerances set in Fusion360.
Fusion CAD may be confused by G91.1. The (rather spiffy) Autodesk G-code editor certainly is. It interprets G91.1 as G91, and the preview and extends calcs in the editor go crazy:
10 years 7 months ago #71475 by gizmo6023
Replied by gizmo6023 on topic Error while loading file
BigJohnT wrote: If you post the G code instead of a screen shot we can see what the problem is.
JT
Here is the file
10 years 7 months ago #71498 by BigJohnT
Replied by BigJohnT on topic Error while loading file
That file runs without any errors in the Axis Simulator. On thing I see is your using % to start and end your code. It is much better to use a program end M2.
Read this carefully. linuxcnc.org/docs/2.7/html/gcode/overvie...de:file-requirements
JT
10 years 7 months ago #71505 by gizmo6023
Thanks JT,
That explains why I have to spend extra time clearing left overs
Time to create page: 0.317 seconds
