latest setup
10 years 7 months ago #72080 by AMelvin
latest setup was created by AMelvin
I'm going to update my 4 axis machine the latest version that is out. Will this require me to update Ubuntu as well?
Current system is 2.5.4 with Ubuntu 10.04 (Lucid)
10 years 7 months ago - 10 years 7 months ago #72086 by Todd Zuercher
Replied by Todd Zuercher on topic latest setup
No, all you should need to do is change or add the repository "deb buildbot.linuxcnc.org/ lucid base 2.7-rtai" then run an update.
instructions are in the docs.
linuxcnc.org/docs/html/getting-started/updating-linuxcnc.html
You might have to make some minor changes to your config files such as commenting out or removing the line
loadrt probe_parport
if it exists in your hal file.
Last edit: 10 years 7 months ago by Todd Zuercher.
Time to create page: 0.099 seconds
