Show axes letters instead numbers
10 years 4 months ago #75389 by isladelobos
How?
In the .ini file?
TRAJ] #+ machine specific settings AXES = 9 COORDINATES = X Y Z B C W HOME = 0 0 0 0 0 0
#- Introductory graphic INTRO_GRAPHIC = emc2.gif INTRO_TIME = 5 EDITOR = gedit INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm GEOMETRY = XYZBCUVW #LAST_POSITION = last_position.txt
Or hal file.
This is one XYZBCW steppers machine.
I use for display tkem
10 years 4 months ago #75397 by andypugh
Which kinematics file are you using? Which version of LinuxCNC?
10 years 4 months ago - 10 years 4 months ago #75411 by isladelobos
Hi.
Im using 5axiskins with 2.6.8
Last edit: 10 years 4 months ago by isladelobos.
10 years 4 months ago - 10 years 4 months ago #75414 by andypugh
[strike]I don't know how to switch from Joint Mode to World Mode in tklinuxcnc.
In the Axis interface you use the $ keyboard shortcut.
tklinuxcnc is currently deprecated, and is probably a poor choice for a non-trivial kinematics machine.[/strike]
This was mainly incorrect info.
Last edit: 10 years 4 months ago by andypugh.
10 years 4 months ago #75420 by andypugh
Use the "World Mode" checkbox to display XYZ rather than 012.
The following user(s) said Thank You: isladelobos
10 years 4 months ago - 10 years 4 months ago #75422 by isladelobos
Stuff !!! thas was simple!!! :ohmy:
Thanks and sorry for the delay.
Last edit: 10 years 4 months ago by BigJohnT. Reason: G rated forum
Time to create page: 0.336 seconds
