Linuxcnc - parallel port vs mesa card
9 years 8 months ago #88102
by Karri
Replied by Karri on topic Linuxcnc - parallel port vs mesa card
Thanks,
So Mesa card will calculates the pulses itself and the reports value of position (or speed? ) to Linuxcnc - not the individual pulses?
Karri
Karri
9 years 8 months ago #88107
Replied by tommylight on topic Linuxcnc - parallel port vs mesa card
Yes
9 years 8 months ago - 9 years 8 months ago #88111
by BigJohnT
Replied by BigJohnT on topic Linuxcnc - parallel port vs mesa card
I asked Peter when I was adding an encoder to my BP knee mill and he said the encoder input can count up to 1MHz or 1,000,000 cycles per second. So if you have a 2500 ppr encoder you can spin it at 12,000 RPM. Pretty impressive I'd say.
Edit: this was for my 7i77 card.
JT
JT
Last edit: 9 years 8 months ago by BigJohnT.
9 years 8 months ago #88147
Replied by PCW on topic Linuxcnc - parallel port vs mesa card
Yeah the maximum encoder count rate for the Mesa cards depends on a number of variables
1. ClockLow rate (33 MHz to 100 MHz depending on card)
2. Muxed on Non-muxed, muxed encoders top out at a couple MHz Max, non muxed up to about 10 MHz
3. Digital filtering settings (settable to 3 or 15 sample clocks, sample clock can be up to 8 MHz on mulltiplexed
encoders and up to ClockLow on non Muxed counters.)
Time to create page: 0.165 seconds
