Stepper Index Homing
  • OT-CNC
  • Topic Author
  • Platinum Member
  • Platinum Member
10 years 2 months ago #79575 by OT-CNC
Stepper Index Homing was created by OT-CNC
From the INI docs:
HOME_USE_INDEX = NO - If the encoder used for this axis has an index pulse, and the motion card has provision for this signal you may set it to yes. When it is yes, it will affect the kind of home pattern used. Currently, you can’t home to index with steppers unless you’re using stepgen in velocity mode and PID.
Is index homing for steppers being developed? I'm using my DMM drives in stepper mode as I never got the pid right in velocity mode. I'd still like to use the index for precision homing.
10 years 2 months ago #79626 by andypugh
Replied by andypugh on topic Stepper Index Homing
Try it.
The homing code doesn't actually know that you are using position-mode steppers.
Time to create page: 0.117 seconds
