- Thank you received: 75
Job Counter and Machine on Time
- OT-CNC
- Topic Author
10 years 2 months ago #79577
by OT-CNC
Job Counter and Machine on Time was created by OT-CNC
Is there a feature that works with axis to keep track of machine on time, spindle on time, servo time and a re-settable job counter of machine time?
And maybe something similar to mach that keeps track of total axis distance traveled?
- Rick G
- Thank you received: 114
10 years 2 months ago #79582
by Rick G
Replied by Rick G on topic Job Counter and Machine on Time
- OT-CNC
- Topic Author
10 years 2 months ago #79588
by OT-CNC
Replied by OT-CNC on topic Job Counter and Machine on Time
Hi Rick G, thanks for the link. I'll have a look.
- OT-CNC
- Topic Author
8 years 5 months ago #111375
by OT-CNC
Okay, I'm revisiting this. I tried adding another pypanel to axis gui and I ran into issues loading it. I currently have a spindle at speed/rpm panel. How do I add the example from the time link to be visible below the existing panel? I'm new to pyVCP code. Can I simply add it to the spindle code or should it load as a separate file? It errored out when I combined the two.
8 years 5 months ago #111473
Replied by andypugh on topic Job Counter and Machine on Time
Axis only supports one side panel.
You need to add your stuff to the XML. But it needs to be valid XML (so your stuff needs to be inside the main XML tags.
It might help to use an XML-aware editor.
Time to create page: 0.249 seconds
