Cant it be solved ? LinuxCNC slows down even dead
- boy777
07 Sep 2016 17:18 #80139
by boy777
Cant it be solved ? LinuxCNC slows down even dead was created by boy777
hi everybody,
the big big problems,
the LinuxCNC slows down at corners and arc.
can't it be solved?
it irritate much, that some mintues work takes hours to complete
Which still not give fine finish.
Also the axis vibrate a little when emergency is pressed . about 0.05mm per press!
when i turn off machine, Z axis goes down , sometimes 0.1mm or sometimes 0.2mm
Stuck between , don't know where to go...
can't it be solved?
- Thank you received: 5325
07 Sep 2016 17:28 #80142
The following user(s) said Thank You: boy777
- boy777
07 Sep 2016 17:37 #80145
by boy777
Replied by boy777 on topic Cant it be solved ? LinuxCNC slows down even dead
this means that the issue can't be solved ????
there is no way ......?
i don't think so, every problem have a solution.
this arc slow doesn't happens in other controls.
07 Sep 2016 17:45 #80147
Replied by PCW on topic Cant it be solved ? LinuxCNC slows down even dead
No, there is no issue.
What it means is that you need to read and understand the trajectory planner setup
in the linked page, and then use the proper prefix gcodes to setup the trajectory planner
to suit your job
to suit your job
- boy777
07 Sep 2016 17:57 #80149
by boy777
that didn't help much,
i think you are saying about G61 and G64 codes....
finishing stops much in corner and arc, that doesn't meet modern age requirement.
stucks in finshing , delays in line reading, stoping at curves.
take much much time, cant get final finish with G64..
codes doesnt help much to have fine corners.
07 Sep 2016 18:01 #80150
Are you running LinuxCNC 2.7? LinuxCNC 2.7 has a faster trajectory planner
for gcode with lots of small segments
LinuxCNC 2.6.x is not as fast for similar GCode
- Thank you received: 1476
07 Sep 2016 18:16 #80152
Replied by Todd Zuercher on topic Cant it be solved ? LinuxCNC slows down even dead
When you tried G64 did you use just G64 in your code, or did you us G64 Px (x being a tolerance number defining how precisely the programed path must be followed). Good starting numbers might be 0.005-0.001 for an inch machine 0.1-0.01 for metric.
G64 by itself usually is not very useful, it will go as fast as possible accuracy be damned. (similar to the G64 behavior on older Fanuc machines without G08 P1 Advanced Preview Control )
- boy777
07 Sep 2016 19:51 #80162
by boy777
running on machine 2.4.x
studying 2.7.x , if it helps would shift to new
you mean with 2.7.x , I'll have a smooth arc corner with fast speed and exact sizes?
how can i backup my old configs and import them to new?
- boy777
07 Sep 2016 19:58 #80164
by boy777
with P , does it not effect the speed ?
the edges that it makes in curves also demolish job look
if not , i would rather changed drawing to get exact sizes.
otherwise the part is rejected.
sorry but mostly my work is of precise accuracy ....
i can't compromise much at that point.
- Thank you received: 7478
07 Sep 2016 20:07 #80166
Replied by tommylight on topic Cant it be solved ? LinuxCNC slows down even dead
It looks like you have the acceleration set very low. Raise it.
It would also help if you could share more information about your machine and setup.
Time to create page: 0.144 seconds
