Annoying stepper's sound
10 years 2 weeks ago - 10 years 2 weeks ago #81593 by Marfil
Hi. Ones again.
In my router, I have a very high sound- It is a variable frecuency and It is very annoying.
I think that is from stepper but I'm not sure.
Anybody have any suggestion / advice to reduce it?
The steppers are from China.
Thanks in advance.
Last edit: 10 years 2 weeks ago by Marfil.
10 years 2 weeks ago #81594 by tommylight
Replied by tommylight on topic Annoying stepper's sound
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /var/www/html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 320. Please enable debug mode for more information.
10 years 2 weeks ago #81608 by Marfil
Replied by Marfil on topic Annoying stepper's sound
tommylight wrote: You can use these to dampen the sound and vibrations, i use plenty of those.
They will not totally remove the noise and vibrations, but they will make everything a lot quieter and more pleasing to the ear.
Thanks Tommylight !!! It is an excellent suggestion.
Now, regarding the variable audio frecuency sound; it is helpful this motor damper? this sound is all the time, and is more evident when the stepper not rotate. Really is very annoying.
Thanks for your answer.
10 years 2 weeks ago #81614 by tommylight
That is the noise produced by the drive PWM current limiting so here are some tips:
Try a different power supply, cheap power supplies produce way to much ripple.
Adding 220 to 470uf capacitors directly to each drives power terminals should lower or completely get rid of that noise.
As a side note, the TB6xxx series drives will need also some 0.1 to 0.47 uf capacitors in parallel with power supply, or even betteter said capacitor should be added inside the drives connected between ground and the "VRef" input to IC.
The following user(s) said Thank You: Marfil
10 years 2 weeks ago #81630 by Marfil
tommylight wrote: That is the noise produced by the drive PWM current limiting so here are some tips:
Thanks Tommylight, I understand all your suggestion. I'll open the drivers box and I'll analyse the electrical circuit. As I told you is an "almost home made" router.
Thanks. a lot.
10 years 2 weeks ago #81631 by tommylight
Opening the drives is a last resort, you have plenty to test with without opening them. Do test at the exact order i wrote them above. Chances are you will get satisfying results before reaching the "open the drive" point.
Opening them would require good knowledge of electronic and schematics and soldering skills, or the magic smoke will escape from them ! :)
Anyway you decide to go, i will be here to help, just do not hope you will completely get rid of it, you won't.
FYI, i never did try to remove that noise, i just like it and it reminds me that one of machines in ON. I can hear even some connected to some high tech stepper drives made by LAM Technologies, as they are de facto the best drives i had in my lifetime. I have used plenty of the DS series, have a look
www.lamtechnologies.com/Resources/Doc/DS10_BRUK.pdf
Time to create page: 0.063 seconds
