As the title asks...When will version 2.8 be "Officially" released?
I know that the "Pre" version is available to install now, but I would prefer to use the officially documented and supported release.
I've used previous versions for my cartesian machine, but I really want to design non-trivial parallel kinematic machines.
Since version 2.8 has the Joint-Axes branch merged, I am assuming that all non-cartesian machine movements including jogging, homing, limits, etc will act as normally as they do for cartesian machines. Is this assumption correct?
If there are any "gotchas" or other problems with non-cartesian machine movement, can someone please list or update those problems here.
Thank you for any answers you can provide.
