Ethernet PokeysCNC LinuxCNC
10 years 14 hours ago #82299 by DaBit
Replied by DaBit on topic Ethernet PokeysCNC LinuxCNC
There is currently no support for the Pokeys57CNC board as a motion controller.
What Mesa hardware are you using? If it is 5i25/6i25: do you use the second port?
The 5i25/6i25 has no problems running two breakoutboards. It would not be too expensive to buy a second 7i76 or whatever you need and a cable. Probably even cheaper than a Pokeys57CNC.
10 years 14 hours ago #82300 by timmert
Replied by timmert on topic Ethernet PokeysCNC LinuxCNC
Thanks for the fast Reply.
I already had a Pokeys57cnc laying around.
My next lathe will be running mesa hardware :)
Mach3 for now
8 years 4 months ago #111646 by chimeno
Replied by chimeno on topic Ethernet PokeysCNC LinuxCNC
Hi DaBit,
I am using the Pokeys57E with the Ponet panel for the keypad in my linuxcnc panel, could you publish your component that you made to control it using TCP?
Thank you
Chimeno
8 years 4 months ago #111650 by DaBit
Sure, no problem:
component voorpaneel "Driver for DaBit Emco8 front panel"; option userspace yes; option extra_link_args "-lPoKeys -lusb-1.0 -lm"; pin out bit isconnected "true when the pokeys device is found and connected"; pin out bit chgpump_out "toggling charge pump output. May be used to check if the component is alive"; pin out bit jog_z_up "Joystick z-up direction"; pin out bit jog_z_down "Joystick z-down direction"; pin out bit jog_x_up "Joystick x-up direction"; pin out bit jog_x_down "Joystick x-down direction"; pin out bit jog_sel_speed1 "connect the jog-sel-speedX pins to gmoccapy jog-inc-X"; pin out bit jog_sel_speed2; pin out bit jog_sel_speed3; pin out bit jog_sel_speed4; pin out signed wheel_jog_x_counts "X axis handwheel jog counts"; pin out signed wheel_jog_z_counts "Z axis handwheel jog counts"; pin out float wheel_jog_scale "jogwheel scale, 1/0.1/0.01/0.001 machine units"; pin out float jogspeed_slider "Jogspeed pot output, range 0.0-1.0. Connect to gmoccapy.jog-vel-value"; pin out float rapidspeed_slider "Rapidspeed pot output, range 0.0-1.0. Connect to gmoccapy.rapid-vel-value"; pin out float feedspeed_slider "feedspeed pot output, range 0.0-1.0. Connect to gmoccapy.feed-override-value"; license "GPL"; ;; #include "PoKeysLib.h" #include <unistd.h> /* UNIX standard function definitions */ #include "math.h" #define POT_EPSILON 0.005 #define POT_AVGCNT 4 int first = 1; sPoKeysDevice * dev=0; int i=0, avgidx=0; float avg_jog[POT_AVGCNT]; float avg_feed[POT_AVGCNT]; float avg_rapid[POT_AVGCNT]; void user_mainloop(void) { while(1){ float ftmp; FOR_ALL_INSTS() { isconnected = (dev!=NULL); if(first){ dev = PK_ConnectToDeviceWSerial(23249, 1000); /* Oh well, for personal use adding the serial in code is OK */ if (dev) { PK_PinConfigurationGet(dev); PK_EncoderConfigurationGet(dev); usleep(50000); first=0; } } else if (dev) { /* Fetch values from Pokeys device */ if (PK_EncoderValuesGet(dev) != PK_OK) { dev=NULL; } if (PK_DigitalIOGet(dev) != PK_OK) { dev=NULL; } if (PK_AnalogIOGet(dev) != PK_OK) { dev=NULL; } if (dev) { /* joystick pins. Note that indexes are one lower than the pokeys pin number */ jog_z_up = dev->Pins[31].DigitalValueGet; jog_z_down = dev->Pins[32].DigitalValueGet; jog_x_up = dev->Pins[29].DigitalValueGet; jog_x_down = dev->Pins[30].DigitalValueGet; jog_sel_speed1 = dev->Pins[39].DigitalValueGet; jog_sel_speed2 = dev->Pins[38].DigitalValueGet; jog_sel_speed3 = dev->Pins[37].DigitalValueGet; jog_sel_speed4 = dev->Pins[36].DigitalValueGet; /* feed overrides. ain-4 is jogspeed, 5 is rapid, 6 is feed */ ftmp=0; avg_jog[avgidx] = ((float)dev->Pins[44].AnalogValue) / 4095.0; for (i=0;i<POT_AVGCNT;i++) ftmp+=(1.0/(float)POT_AVGCNT)*avg_jog[i]; if (fabs(jogspeed_slider - ftmp) > POT_EPSILON) jogspeed_slider = ftmp; ftmp=0; avg_rapid[avgidx] = ((float)dev->Pins[45].AnalogValue) / 4095.0; for (i=0;i<POT_AVGCNT;i++) ftmp+=(1.0/(float)POT_AVGCNT)*avg_rapid[i]; if (fabs(rapidspeed_slider - ftmp) > POT_EPSILON) rapidspeed_slider = ftmp; ftmp=0; avg_feed[avgidx]= ((float)dev->Pins[46].AnalogValue) / 4095.0; for (i=0;i<POT_AVGCNT;i++) ftmp+=(1.0/(float)POT_AVGCNT)*avg_feed[i]; if (fabs(feedspeed_slider - ftmp) > POT_EPSILON) feedspeed_slider = ftmp; if (++avgidx >= POT_AVGCNT) avgidx=0; /* handwheels */ wheel_jog_x_counts = dev->Encoders[0].encoderValue; wheel_jog_z_counts = dev->Encoders[1].encoderValue; ftmp=0; if (dev->Pins[54].DigitalValueGet) ftmp += 1.0; else if (dev->Pins[52].DigitalValueGet) ftmp += 0.1; else if (dev->Pins[51].DigitalValueGet) ftmp += 0.01; else if (dev->Pins[50].DigitalValueGet) ftmp += 0.001; wheel_jog_scale = ftmp; //for(i=0;i<55;i++)dev->Pins[i].DigitalValueSet=out(i); //PK_DigitalIOSet(dev); chgpump_out = !chgpump_out; usleep(50000); } } else { /* No device handle. Setup default values */ jog_z_up = false; jog_z_down = false; jog_x_up = false; jog_x_down = false; jog_sel_speed1 = true; jog_sel_speed2 = false; jog_sel_speed3 = false; jog_sel_speed4 = false; jogspeed_slider = 0.5; rapidspeed_slider = 0.5; feedspeed_slider = 0.5; /* Restart init */ first = 1; } } } exit(0); }
Mind you: this is a purpose-written component, not very generic. However, it should be easy to adapt to your situation.
To compile this run 'sudo halcompile --install voorpaneel.comp' (or without the sudo if you are running a RIP install). You will need libusb-1.0.0-dev and the 'mbosnak' PoKeys library.
The following user(s) said Thank You: chimeno, silopolis
8 years 4 months ago #111652 by chimeno
Hi DaBit,
Thank you very much for sharing your code, given that it connects via USB serial no? I have POKEY57E in ethernet mode works with TCP IP ??
thanks for everything
Chimeno
8 years 4 months ago #111663 by DaBit
I am using Ethernet also. So far I had exactly zero issues with the Pokeys57E which cannot be said from the 57U. USB and CNC machines are a bad match.
But it works seamless with both Ethernet and USB. The PK_ConnectToDeviceWSerial function in the code uses the PoKeys serial number to find the right device, and the data transport is abstracted away by the PoKeys library.
Time to create page: 0.066 seconds
