I have designed the table to be able to use all these different tools.I have started welding the table and getting all the mechanical components together. While i wait for all that to come in i have three types of motion controls im considering. Not likely the tried old stepper, BLDC with encoders 1000ppr, DC servo disc with 2000ppr. Id perfer using the DC servo disc since i have the drivers and higher resolution. The drivers run on PWM and DIR(high low). The closed loop system will improve my accuracy and reduce costs.
Room for growth - I was hoping to implement later this project into a 5 axis router with a z 3 axis spindle. So this is a side note for consideration.
Which mesa combination will get me at least up and runnning with a 3 axis setup ?
I considered the 5i20 with 7I52S i am not a EE so be kind. I am a hobbiest learning.
