Mesa 5i25 and single 7i76 have wrong pins [SOLVED]
9 years 6 months ago #91216 by ebartel
Sorry for the delay, I didn't have time to work on it last night.
Still same results. Here is the output.
ebartel@prototrak:~/Downloads/5i25/configs/hostmot2$ pwd /home/ebartel/Downloads/5i25/configs/hostmot2 ebartel@prototrak:~/Downloads/5i25/configs/hostmot2$ md5sum 5i25_7i76x2 5i25_7i76x2.bit 5i25_7i76x2r.bit 5i25_7i76x2r.xml 5i25_7i76x2.pin 5i25_7i76x2r.pin 5i25_7i76x2.xml ebartel@prototrak:~/Downloads/5i25/configs/hostmot2$ md5sum 5i25_7i76x2 5i25_7i76x2.bit 5i25_7i76x2r.bit 5i25_7i76x2r.xml 5i25_7i76x2.pin 5i25_7i76x2r.pin 5i25_7i76x2.xml ebartel@prototrak:~/Downloads/5i25/configs/hostmot2$ md5sum 5i25_7i76x2.bit cfe35f4106871ef627e6f0ad38cfa78e 5i25_7i76x2.bit ebartel@prototrak:~/Downloads/5i25/configs/hostmot2$ sudo mesaflash --device 5i25 --write 5i25_7i76x2.bit [sudo] password for ebartel: Sorry, try again. [sudo] password for ebartel: Checking file... OK File type: BIT file Design name: TopPCIHostMot2b.ncd;UserID=0xFFFFFFFF Part name: 6slx9tqg144 Design date: 2015/12/21 Design time: 16:46:04 Config Length: 340604 Boot sector OK EEPROM sectors to write: 6, max sectors in area: 16 Erasing EEPROM sectors starting from 0x100000... |EEEEEE Programming EEPROM sectors starting from 0x100000... |WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW Board configuration updated successfully. You must power cycle board to load updated firmware. ebartel@prototrak:~/Downloads/5i25/configs/hostmot2$ sudo mesaflash --device 5i25 --verify 5i25_7i76x2.bit Checking file... OK File type: BIT file Design name: TopPCIHostMot2b.ncd;UserID=0xFFFFFFFF Part name: 6slx9tqg144 Design date: 2015/12/21 Design time: 16:46:04 Config Length: 340604 Boot sector OK Verifying EEPROM sectors starting from 0x100000... |VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV Board configuration verified successfully ebartel@prototrak:~/Downloads/5i25/configs/hostmot2$ sudo mesaflash --device 5i25 --reload
9 years 6 months ago - 9 years 6 months ago #91220 by PCW
Did you do a full power cycle of the machine? (reboot will not do)
Also what OS are you running (uname -a) (sorry already asked that)
I am assuming you are _not_ running pathpilot
Last edit: 9 years 6 months ago by PCW.
The following user(s) said Thank You: ebartel
9 years 6 months ago #91243 by ebartel
As expected, it was a simple issue. I was rebooting the host and did not power off/on. I appreciate the help on this.
Time to create page: 0.289 seconds
