2.7.8 Trajectory Planner settings for 3d work
9 years 5 months ago #92510 by beltramidave
Hi Chris,
Thanks for the heads up on the Preview control. I had seen that in the past, but never thought about using it.
My PC specs are attached. They are correct other than I have 2gb RAM. I have a lower base period (40000) with this machine than my last one (100000), so I am sure that is why I am noticing the difference in loading speed.
9 years 5 months ago #92538 by beltramidave
Todd Zuercher wrote: One thing that might make a difference, is using different G64 P and Q settings. By default Q when not specified is set equal to P. So instead of just G64 P0.01, try G64 P0.01 Q0.001 and see if the precision is any better. It might not make much if any difference, then again, never know till you try.
Ok, so I tried this and it made absolutely no difference in time or as far as I can tell quality in the carvings.
Dave
9 years 5 months ago - 9 years 5 months ago #92540 by Todd Zuercher
It was a long shot to see if the naive cam detection was screwing with your quality. And the answer apparently is no. You are probably just up against the physical limits of your configuration, and the only way to go faster would be to increase your accelerations. Assuming the mechanics of the machine can handle it, if not, you're done.
Last edit: 9 years 5 months ago by Todd Zuercher.
Time to create page: 0.052 seconds
