Thanks tommylight. Good that you said that about the angular bearings, because i think i would order the wrong one..
I think 10m/min. is okay for me, but i am wondering if i reach 10m/min on the gantry axis (will be X i think) when using 2005 ball screw with direct drive.
Cutting at 10m/min is not really necessary for me, so i think there should be no problem when it comes to torque and when cutting at lower speed, i could make deeper cuts. Also like you are saying with the 05 screw i have more force so it will be totally fine ( i think
@Todd Zuercher: When you are saying "servos", you mean real servos and not the the hybrid servos, right ? Because the hybrid servos are like steppers, but running quieter and have maybe couple more advantages + closed loop.
Guys, does it makes sense to go for closed loop hybrid stepper? I mean, will it make an big difference when using 2 motors for one axis ? I dont know anymore where i read it, but somewhere someone wrote its good to have servos or at least closed loop hybrid steppers when using 2 motors for one axis.
