multiple test sub return value
9 years 5 months ago #93662 by albova
yes, at the trigger touchprobe, no message and the program stops.
9 years 5 months ago #93663 by andypugh
Does it stop/exit or stop/stall?
I wonder if feed-override or feed-per-rev is active?
9 years 5 months ago #93695 by albova
Sorry, I replied badly.
When the probe reads, the program goes out as if it was finished (eg M30) and no error message appears. In fact, the position is correct, with a deviation of 0.02 mm. The tool remains supported on the probe and all manual and MDI controls are enabled. It seems he can not finish the G38.2 command and exit. If, however, I start the program from the beginning, it will be fine until the second tool check is when I have to resume with the command "run from here". No use to program feed-override or feed-per-rev, obviously by default already has a G94. I would have thought of another solution. If the tool is not ok, I could do a python program where to insert the line from which it should start and cut off everything that is before (other than the headers). It seems that by resuming the program from the start and not from a point, the problem does not persist.
Time to create page: 0.149 seconds
