Machine won't jog or run a program
9 years 3 months ago #96871 by Doug Funny
Here you go Sir...
9 years 2 months ago #96886 by andypugh
# Spindle Contactor - False when spindle contactor is energized net SOFF hm2_5i20.0.gpio.033.in motion.feed-hold
SOFF doesn't seem to be mentioned anywhere else in this HAL file though.
The INI file references a second HAL file and a postgui Hal File, (htough I can't off-hand see where they are called from) can we have those too.
[HAL]
HALUI = halui
HALFILE = 622leadshine.hal
EZTROL_HALFILE = 5i20eztrol.hal
POSTGUI_HALFILE = axis_manualtoolchange.hal
9 years 2 months ago #96949 by Doug Funny
Well I feel stupid and deserve to be publically shamed....
On the Smithy 622 there is a "spindle guard" which is nothing more than a piece of plexi-glass on a shaft with a cam on the end of the shaft. Open the door switch closes, machine don't run. Close the door switch opens machine can run.
the plexi-glass fell of years ago and I never paid the shaft much attention, that is until today...
Turns out the micro switch was bad, so I jumped the wires and machine runs fine!
Thanks for helping me out, it's nice to know there are people out there willing to share their experience and knowledge with others.
Doug
9 years 2 months ago #96950 by andypugh
And thanks for reporting back. Next time we see this, we can suggest that solution.
The following user(s) said Thank You: Doug Funny
8 years 11 months ago #101418 by cintsa cnc
I am not sure this is the right place for my problem but it is similar. i am using "AXIS" . Everything was working fine until I ran the config. wizard to improve the accuracy of the X and Y axis. Now I am able to load a program as usual but when I hit the run button, the controls dull out as usual but the program will not run. when the stop button is pressed all the controls come back to normal.
I am able to manually jog the three axis as well as use MIDI commands to move the axis I tried resetting the config file back to what t was but the problem still exists. The machine will run the start up program LINUX CNC engrave.
I have attache d the Ini. and Hal. files in case there is something I have missed
8 years 11 months ago #101423 by andypugh
This sounds like a feed-override or spindle-at-speed problem.
Possibly the sample code sets over-ride on these:
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m48-m49
Alternatively, perhaps the sample code does not select a tool, and your code does, but the tool-change loop is not configured.
To test this second theory, hat happens if you enter T1 M6 in the MDI window?
Time to create page: 0.131 seconds
