Z axis stalling when jogging from pendant
01 Nov 2017 19:39 #101147 by vmihalca
Hi guys,
I'm having an issue with my bench lathe that I've converted to cnc.
On the Z axis, when I jog from the keyboard, it does fine in the whole range of speeds, the max speed is 1500mm/min.
When I jog it from the pendant, with the highest x100 set on the pendant, the motor stalls.
I thought is a driver issue, a setting issue or smth...but I've switched the cables with the X axis, and the X motor goes fine, and the Z stalls again. The half nut is not engaged, so its just the screw itself.
If anyone can give me some hints I would be grateful! :)
Thanks,
Vasi
03 Nov 2017 16:29 #101266 by andypugh
Replied by andypugh on topic Z axis stalling when jogging from pendant
It might be that the commands from the pendant are too "jerky".
This HAL component might help:
linuxcnc.org/docs/2.7/html/man/man9/ilowpass.9.html
09 Nov 2017 07:57 #101538 by vmihalca
Replied by vmihalca on topic Z axis stalling when jogging from pendant
Hi Andy,
I had ilowpass filter but I had wrong values for gain and scale. I've played a bit with the values and now it does exactly what I expect, it also has acceleration/deceleration. Thanks! :)
Also I would have another question! :)
My pendant is for 4 axis and since I'm using a lathe I only use 2 axis. Can I wire one of the other axis inputs so that I can increase/decrease feed override using the MPG wheel?
If so, can you give me some instructions or redirect me to some resources? I'm using Mesa 7i76e.
Thanks! :)
09 Nov 2017 09:55 #101541 by andypugh
Yes, you can easily use the jog wheel for feed override and spindle override.
You probably already have the wheel counts connected to axis.0.jog-counts and axis.2.jog-counts. You also need to connect it to halui.spindle-override.counts and halui.feed-override.counts. Then just as the selector pins are connected to axis.0.jog-enable and axis.2.jog-enable you need to connect other pins to halui.spindle-override.count-enable and halui.feed-override.count-enable.
linuxcnc.org/docs/2.7/html/man/man1/halui.1.html
11 Nov 2017 21:00 #101666 by vmihalca
Hi Andy,
I did managed to make the feed override slider move when I jog the weel. Unfortunately due to ilowpass.scale, on one mpg pulse it goes from 0 to 200.
I would like to increase by 1% on each pulse. What setting do I need for this?
I'm attaching the .hal file so that you can understand better the settings I have.
File Name: custom_201...11-2.hal
File Size:2 KB
11 Nov 2017 21:11 #101667 by andypugh
You need much smaller increments for the jogs. (you need to divide them by the ilowpass scale).
11 Nov 2017 21:38 #101669 by vmihalca
For the x and z axis, the increments are fine, they move as they should. I don't know where to specify the increments for the feed rate. If you can have a look over the file, perhaps you can figure it out.
Thanks man!
11 Nov 2017 21:42 #101670 by andypugh
Just don't use the ilowpass-ed counts for override
Change
net encoder-counts <= ilowpass.0.out
net encoder-counts => axis.0.jog-counts
net encoder-counts => axis.2.jog-counts
net encoder-counts => halui.feed-override.counts
To
net mpg-out => halui.feed-override.counts
11 Nov 2017 21:50 #101672 by vmihalca
It works! :D
Thanks for being so responsive.
Right now at each pulse it increments by 10%, is there a simple way to increase it just by 1%?
This way the jog wheel would not be so sensitive :)
Thanks again! :)
11 Nov 2017 21:56 #101673 by andypugh
I see halui.feed-override.scale and halui.spindle-override.scale in the manual page
Try adding
setp halui.feed-override.scale 0.1
and see what happens.
Time to create page: 0.116 seconds
