I have a cnc router with 2.8 master installed on Wheezy. Everything seems to work well except the MPG. It's probably some stupid mistake I made, but the jog increments with the MPG are in metric (verified with an indicator on all 3 axis').
I've checked and verified X, Y, and Z move as commanded in MDI and with the jog buttons in both GMOCCAPY and AXIS make incremental moves in inches.
My router was originally configured with the PnCConf wizard and I looked over the HAL file, but I don't see anything wrong. I'm using a cheap, handheld MPG that I got off ebay. Most MPGs are 100 count, maybe mine is different? Is there a location in the INI or HAL file to change the counts?
