Checking accuracy of microswitches
8 years 8 months ago - 8 years 8 months ago #105354 by Desertboy
Hi is there an easy way to check the repeatability and accuracy of my microswitches? Hoping there's a program for this.
I have a 1.2m*0.7m bed I would like worst case scenario
Last edit: 8 years 8 months ago by Desertboy.
8 years 8 months ago #105362 by kornphlake79
The easy way is to setup an indicator so that the axis in question moves onto the indicator as it moves onto the home switch (or off the switch depending on how you have homing configured). Set zero on your indicator after homing is complete then repeat the homing procedure several times and record the variation from the indicator.
Time to create page: 0.169 seconds
