Hi Bengt, thanks again fo the reply. Sorry to be a pain, but I am new Linuxcnc and the spindle encoder is the part I was worried about when upgrading from Mach3.
In your last picture you have posted a cad diagram with the A and B pulse being binary opposite to each other e.g A being 0 and B being 1. I would have expected the pulse diagram to look like this:
image missing https://www.pcpairgunspares.co.uk/images/encoder2a.png
Whereas the pulse picture I posted shows A as 0 and B as on the leading edge of 1.
image missing https://www.pcpairgunspares.co.uk/images/encoder2b.png
I would then expect the cad drawing (borrowed your drawing I hope you don't mind) to show the B location to be on the red line.
image missing https://www.pcpairgunspares.co.uk/images/tecno.png
In effect your picture A and B seem to be 180degrees out of phase with each other rather than 90degress.
Obviously 90degrees out of phase would make positioning the sensors quite difficult, but positioning them in a binary opposite fashion as you have would be a lot easier. However I notice you have tested this and it seems to work OK with linuxcnc?
Also what setting did you use for this configuration?
Again thanks for taking the time to reply - any assistance is greatly appreciated.
Steve
