Hello!
I ve been working on a retrofit for ages, got my degree before getting the mesa 5i25 and 7i77 so the project was put on hold due to work. I finally have some time to work on it again, but I can't seem to get the 7i77 to cooperate...
I connected the 5i25 to a PCI slot on a fairly old lab desktop pc, jumper W2 set to "up" position.
I connect the 5i25 to the 7i77 via db25, jumper W5 on the left and started a halrun on the terminal. The pins seem to be there, but the CR16 led is shining red and I don't seem to have communication. I tried connecting one encoder and setting up a halmeter to test encoder position while manually turning the shaft but nothing shows.... (while turning I put a multimeter on the encoder pins themselves, the voltage was changing with rotation
Just to clarify.... my setup uses analog drives that receive resolver input from the motors. The drive itself is equipped with a circuit that converts resolver input to encoder output. As a result the encoder is self powered.
Any ideas to get started?
I upload the encoder's connector pin description, I would be grateful for some opinions on how to properly wire it to the 7i77...
Thanks in advance!
