Encoder Mesa Karte low cost
8 years 3 months ago #113212 by dirk61
Hello
My machine is currently working with 5I25 / 7I77 / 7i74 / 7I70 / 7I71 /
Now I wanted my handradencoder and my feed override encoder
Unfortunately, the 7I70 does not manage to detect the signals. Apparently the current is too low.
Is there a card from Mesa that processes the encoder signals for little money?
Or does someone have a ready low cost solution?
Mfg Dirk
8 years 3 months ago #113224 by PCW
Replied by PCW on topic Encoder Mesa Karte low cost
The 7I77 can support 2 MPGs on its field I/O (inputs 16,17,18,19)
If you want a remote card for this, the 7I73 is a possibility, it supports up to 4 MPGs
8 years 3 months ago #113298 by dirk61
Replied by dirk61 on topic Encoder Mesa Karte low cost
Hello
I tend to the 7I73
Could get potentiometer in 1K / 4.7K / 10K / 47K / 100K / 470K ohm for the analog inputs.
What would be the best result in your opinion?
Kind regards
8 years 3 months ago #113331 by PCW
You can use potentiometers with the 7I73 analog inputs
The advantage of potentiometers vs encoders is that they are absolute devices and stay where you manually set them
The disadvantage of potentiometers vs encoders is that they are absolute devices and stay where you manually set them (this make it harder it get along with GUIs controls that may override the manual setting)
Time to create page: 0.143 seconds
