G codes ignored
8 years 3 months ago - 8 years 3 months ago #114094 by Methier
G codes ignored was created by Methier
hi, i've retrofitted an old Milltronics machine, we have a month with the machine finished, also we did some jobs (surfaces, pockets and stuffs), I have a problem now, im doing slots and the machine was not following the right path, I mean the slots are horizontal, and I saw diagonals, so I checked the g code and it looks OK for me, also the path is displayed on the screen, looks like if some lines are ignored by some reason.
I ran the same program before without issues, as I said we did moulds on that and the machine ran flawlessly.
Attached a pic
thanks
Meth
Forgot to say, I checked if there was a following error, tried different arc declarations like I,J,K and lots of small lines, and no difference.
Last edit: 8 years 3 months ago by Methier.
8 years 3 months ago #114097 by cmorley
Replied by cmorley on topic G codes ignored
What version of linxcnc are you using?
Can you post a sample gcode file that has the error?
Do you see the same error in a sim config?
Chris M
8 years 3 months ago #114104 by Methier
Replied by Methier on topic G codes ignored
Version is 2.7.1 I think, I ran it on sim and it was ok.
any hidden function I missed? or something I activated perhaps, what function does that?
Regards
Meth
File Name: 6.ngc
File Size:20.31 KB
8 years 3 months ago #114105 by Methier
I got It working now, well I had to make a new config and copy INI and HAL files, but I wonder what caused it, for future references.
8 years 3 months ago #114156 by andypugh
Replied by andypugh on topic G codes ignored
It looks a _bit_ like a wierdness with diameter compensation.
8 years 3 months ago #114174 by Methier
it could be, I thought that too perhaps I pressed tool touch off on X or Y axis instead of touch off, but based on that I cleared tool offsets and cleared work offsets too, and the problem was still there.
Regards
Meth
Time to create page: 0.359 seconds
